Newbie first install questions. - Road Glide Forums
post #1 of 10 (permalink) Old 01-27-2014, 07:20 AM Thread Starter
hometoast's Avatar
So I've got the pair of speakers (JM XX) and an Amp (SS pn2.350d) ... is the only other thing I will need is power cable to run back to battery?
I've never even upgraded a headunit in a car, so it's all new to me.
hometoast is offline
post #2 of 10 (permalink) Old 01-27-2014, 08:08 AM
ERod62's Avatar
Red fused wire to battery positive, black to ground chassis and should have a second + voltage signal, smaller gauge wire connected to an accessories source. Require to turn on/off the amp. I connected to the cigarette lighter. Plus speakers input output.
Good luck.
Sent from Motorcycle.com App
ERod62 is offline
post #3 of 10 (permalink) Old 01-27-2014, 09:49 AM Thread Starter
hometoast's Avatar
Thanks E. If we could get some NEAR freezing (instead of 30-below freezing) weather, I could get out to the inlaws and get some of these winter mods done
post #4 of 10 (permalink) Old 01-27-2014, 10:23 AM
Venomized's Avatar
Good luck.
Agree except ground to the battery.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #5 of 10 (permalink) Old 01-27-2014, 10:30 AM
DewmanCO's Avatar
I have always been told (and followed) instructions to ground to the frame. Away from the battery and as close to the amp as possible for any car audio installations. I would assume the bike would be the same. Why ground to the battery?
Edit - just curious because I'm doing this right now and looking for a solid ground point.
Mathematics - as relentless as the laws of gravity - is nonnegotiable
DewmanCO is offline
post #6 of 10 (permalink) Old 01-27-2014, 10:40 AM Thread Starter
hometoast's Avatar
this is just my guess:
1) you can't really bring EVER grounded device back to the battery, you'd run out of room on the post.
2) makes for easier diagnosis or problems? maybe. a frame-ground is less reliable, but it's "right there next to the amp/radio/horn/whatever"
post #7 of 10 (permalink) Old 01-27-2014, 11:16 AM
Venomized's Avatar
Its a better ground point and I personally got noise and a pop on turn on and off grounding to the frame.
'07 Pewter Pearl
post #8 of 10 (permalink) Old 01-27-2014, 12:12 PM
DewmanCO's Avatar
Sounds good. I guess it isn't that hard to change it. I think I am going to run two fused distribution blocks, one for power and one for ground so I only have to get to the battery this one time. I don't have ABS so I may put them under the right side cover, make life easier if I add heated gear or more stereo stuff.
DewmanCO is offline
post #9 of 10 (permalink) Old 01-27-2014, 08:46 PM
zemo1017's Avatar
There is an orange wire behind the head lights with a crimped push connector on it. It turns on with the ignition. Use that for your remote to the amp.
zemo1017 is offline
post #10 of 10 (permalink) Old 01-28-2014, 04:36 AM
The wiring harness /instructions that came with the J&M Rokker 500w have the + going directly to the battery, the - going directly to the main ground post on the frame.
The cig lighter or the orange aux wire are two good "switched" sources for the amp trigger.
HeatWave is offline
Newbie with new to me bike w some questions Mechanicalmike08 Intake and Exhaust 13 08-06-2015 11:35 AM
Questions from HD Newbie!! Bear714 Intake and Exhaust 6 09-17-2014 09:25 AM
Three newbie questions...... kiwidave *General Road Glide Discussions/Pictures 7 09-27-2013 02:33 AM
Xm radio on 13 cvo questions also a newbie Boss302 New Members Welcome Area 46 08-02-2013 10:46 PM
Newbie Questions: Part 2 Bigdutch Road Glide Specific Discussions 7 12-29-2011 09:34 AM
