Two pbr 300x2 wiring help - Road Glide Forums
post #1 of 7 (permalink) Old 01-28-2014, 10:58 PM Thread Starter
I will be installing two of these amps in a 2013 rgc. I only have two channels coming out of the radio for the factory speakers. Where do I pickup the other two inputs from for the second amp. Any and all help would be great. And some pics of a similar install would be awesome. Thanks Daniel.
texastrendz is offline
post #2 of 7 (permalink) Old 01-29-2014, 08:30 AM
stripclub's Avatar
You can make a y harnes up, use the two outputs you have, and then to both inputs to the PBR amps, it will work fine.
stripclub is offline
post #3 of 7 (permalink) Old 01-29-2014, 09:34 AM
chromedome's Avatar
Best would be to use a Line Out Converter that has dual stereo outputs.
Here is an example...
http://www.crutchfield.com/p_142SLC4...5661345&awdv=c
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #4 of 7 (permalink) Old 02-01-2014, 05:48 AM
09Sharknose's Avatar
You can wire up the rear outputs to run your second amp. The speaker lines on the other side of your radio are hot, just nothing connected to them on the RGC. The lines are at positions 1(r+),2(l+)and 24(r-),25(l-). Your local stealer will get you the posts for pretty cheap. Just wire them as above and voila! Two rear channels! Hope this helps.
09Sharknose is offline
post #5 of 7 (permalink) Old 02-02-2014, 08:41 AM Thread Starter
I am installing this myself and would like to know what are the "post" you are referring to. Thanks Daniel
post #6 of 7 (permalink) Old 02-02-2014, 01:50 PM Thread Starter
Just ordered a 35 pin connector and pins. Thanks
post #7 of 7 (permalink) Old 02-03-2014, 11:41 PM Thread Starter
Got the mounts made from some stainless laying around the shop
Rokker XTs with PBR 300x2 & Ipod interface gfyoung3 Audio 6 04-21-2013 11:44 AM
WTB - RF PBR 300x2 Mounting Bracket outlawjessejames Wanted! (Buy or Trade) 5 03-23-2013 04:02 PM
Alpine PDX F6 or 2 Rockford PBR 300X2's yamahoe72 Audio 3 03-11-2013 11:08 PM
RF PBR 300X2 / Biketronics's Titan II JadaGlide Audio 5 08-31-2012 11:25 AM
Some RG mods including PBR-300x2 Amp install mrwatson Audio 14 04-09-2012 05:37 PM
