Audio newbie question - Road Glide Forums
post #1 of 5 (permalink) Old 02-01-2014, 12:38 PM Thread Starter
maurij1's Avatar
I've been reading through a lot of the audio threads on this forum and a few car audio forums trying to figure out the whole 2ohm vs 4 ohm speaker deal. Reason being, I just want to replace my stock head unit so I can have a few more options. I have the boom audio speakers already both front and back, but I do not have an amp. I will probably buy an amp later but for now just I just want a new head unit. I'm looking at installing the Alpine 149BT, will the 2ohm boom audio's burn out the amp in the head unit if I hook it up without an amp? Will it work as good as the HK head unit for now until I add an amp??
maurij1 is offline
post #2 of 5 (permalink) Old 02-01-2014, 12:42 PM
Venomized's Avatar
They will work fine the Alpine deck. If you add an amp later I would change speakers as well. Those booms cant handle much more than the stock HK throws at em.
The Alpine will be able to handle the speakers just fine.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #3 of 5 (permalink) Old 02-01-2014, 01:47 PM Thread Starter
maurij1's Avatar
Will the sound be a little better than the stock HU? It's loud enough now, would be nice if it was a little clearer though!
maurij1 is offline
post #4 of 5 (permalink) Old 02-01-2014, 02:28 PM
Venomized's Avatar
Itll be better to an extent but its not going to immensely change with just a head unit swap.
'07 Pewter Pearl
post #5 of 5 (permalink) Old 02-01-2014, 02:49 PM Thread Starter
maurij1's Avatar
Ok, thank you! I will do the amp & speakers next year when I get my guages done.
maurij1 is offline
Aquatic AV-JL Audio HX280/4-Polk Audio MM652s, SMD DD1 rustyj671 Audio 6 08-22-2017 02:49 PM
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
Car audio vs motorcycle audio sdlakerfan79 Audio 20 04-11-2013 06:52 PM
Newbie exhaust & intake question... mjohnson68 Intake and Exhaust 14 02-20-2012 07:19 PM
Newbie warranty question musicman8120 *General Road Glide Discussions/Pictures 4 08-19-2010 05:53 PM
