quick dumb question about the hi-input on pn2.350d - Road Glide Forums
post #1 of 11 (permalink) Old 02-04-2014, 10:31 AM Thread Starter
hometoast's Avatar
So when I get the faring off to mount this guy, I'm assuming there's no connector that looks like the 'hi-input' 5-pin block on this amp.
How is the HK unit going to connect here?
hometoast is offline
post #2 of 11 (permalink) Old 02-04-2014, 10:53 AM
jaysrgu's Avatar
I just installed the 4.5,the high input wire would have been in the packaging with the amp,basically you hook right and left channel and a ground to the 5 hi input,if you cant find it I would call a stereo shop and see if there all the same size,you might be able to source it locally
jaysrgu is offline
post #3 of 11 (permalink) Old 02-04-2014, 11:00 AM Thread Starter
hometoast's Avatar
damn. thanks. I'll double-check the box.
post #4 of 11 (permalink) Old 02-04-2014, 11:27 AM
torqu's Avatar
Input through the speakers or through the Rca's. Which are you doing? If using rca's don't worry about it.
torqu is offline
post #5 of 11 (permalink) Old 02-04-2014, 12:16 PM Thread Starter
hometoast's Avatar
I'm keeping the stock HK. So no pre-amp outputs for me (yet)
post #6 of 11 (permalink) Old 02-04-2014, 12:49 PM
Venomized's Avatar
Ultranutz posted this
http://m.hdforums.com/forum/attachme...6&d=1384726065
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #7 of 11 (permalink) Old 02-04-2014, 02:09 PM
jaysrgu's Avatar
venoms link is correct except that the center one is grounded,that what my soundstream booklet says.the guys at sidecar cycles told to to always use the high input if u have one,better quality then thru the rcas,im no pro just passing on what I was told
jaysrgu is offline
post #8 of 11 (permalink) Old 02-05-2014, 08:14 AM
Venomized's Avatar
Maybe not having that grounded is why Im getting a turn on/off pop
'07 Pewter Pearl
post #9 of 11 (permalink) Old 02-05-2014, 08:23 AM
Neano62's Avatar
I had a 'Pop' then shut down on one of my amps once, due to a bad ground!
Scary!!
but thats ur Culprit.
[/IMG]
Neano62 is offline
post #10 of 11 (permalink) Old 02-05-2014, 09:12 AM Thread Starter
hometoast's Avatar
that little 5-pin pigtail was in the box stuck under a flap.
damn this snow, I couldn't even get to the inlaws garage now if I wanted to work on it.
Hi-level input wireing (PN4.520d) NK-Highway Audio 21 01-07-2015 05:11 AM
Disappointed: JM Rokker XX, Soundstream 350D, Alpine 149bt hometoast Audio 12 04-11-2014 05:37 AM
quick/dumb question about headunit replacement hometoast Audio 4 01-31-2014 09:48 AM
Looking for AMP SSpn2.350d or RFpbr300x2 glide1 Wanted! (Buy or Trade) 2 01-25-2014 11:52 PM
