marine speakers?? ohm rating? - Road Glide Forums
post #1 of 2 (permalink) Old 02-04-2014, 06:47 PM Thread Starter
Thought i knew about speakers but maybe not... Do you need to use water proof speakers in the fairing and pods? And it says 2 ohm on my stock H/K but most speakers i see are 4 ohm.. Can i use 4 ohm? Thanks in advance
midwaywfo is offline
post #2 of 2 (permalink) Old 02-04-2014, 06:54 PM
Most speakers made today are very water resistant, you don't need waterproof speakers, your stock speakers aren't even waterproof. You can use 4 ohm speakers, you just won't be getting the maximum power out of the unit.
Sent from my SPH-L710
Paralleling speakers 4 ohm 2 ohm using amp set up to parrallel Heavy Metal Audio 16 01-06-2018 06:09 PM
Speaker question 2 OHM or 4 OHM Ginee13 Audio 3 09-22-2015 05:53 AM
switching from 4 ohm to 2 ohm at a later date chevjerico Audio 3 05-15-2014 01:24 PM
4 ohm and 2 ohm speakers yamahoe72 Audio 7 04-13-2013 07:55 PM
Anyone make a 8 ohm loprofile marine speaker? Mopar1 Audio 13 01-12-2012 02:45 PM
