RF Punch PBR300x2 - Road Glide Forums
post #1 of 11 (permalink) Old 02-07-2014, 04:13 PM Thread Starter
RF Punch PBR300x2
Hey guys.
Just purchased the Rockford Fosgate Punch PBR300x2. where are you guys grounding the amp. Is there somewhere inside the fairing to ground or do I need to run the ground back to the battery?
Also, Id like the J&M Rokker XX 7inch speakers, but I just cant see paying almost $400 for speakers. Iv read all about the Polk MM651 6.5 inch speakers, but aren't they only rated at 4 ohms. I was looking to get the most out of this amp, but i cant seem to find any other 6.5 inch speakers 2 ohms that can handle 150 watts rms.
help me out.
2013 FLTRX Road Glide Custom, V&H Pro Pipe, Fuel Moto air cleaner, Woods TW-222 cams, Woods Alpha series lifters, Power Vision w/ autotune pro. HD king color match tour pack.
Liquidr1 is offline
post #2 of 11 (permalink) Old 02-07-2014, 04:18 PM
OneSlickGlide's Avatar
MM651's are 2 ohm
OneSlickGlide is offline
post #3 of 11 (permalink) Old 02-07-2014, 04:21 PM
You can ground the amp where the front of the fuel tank mounts to the frame, or take it to the battery. Unless you're going to play your stereo full blast it's ok to have the amp rated a little higher. You're not always going to find a perfect match. BTW the Polk MMs are 2.7ohms. For $400 there are a lot of nice speakers out there I'd go a different route, but that's me. JMs are good, just not my style, if you can, go out and listen to a few different systems before deciding.
Sent from my SPH-L710
post #4 of 11 (permalink) Old 02-07-2014, 04:25 PM
Venomized's Avatar
Infinity 62.9I are 2 ohm
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #5 of 11 (permalink) Old 02-07-2014, 04:41 PM
The new Infinity is the 62.11i same basic speaker, just this years model. One thing I really like about it is the screw in terminals for the wires.
post #6 of 11 (permalink) Old 02-07-2014, 05:55 PM
Wickedgmc's Avatar
Rockford recommends grounding the amp at the battery.......
https://www.dropbox.com/s/8044wxwxqs...llAdvisory.pdf
I have grounded all my amps at the battery on my bike and have never had a grounding issue.
2004 Road Glide FLTRI
Wickedgmc is offline
post #7 of 11 (permalink) Old 02-07-2014, 06:01 PM
+1on that. My instructions say , grounding to motorcycle is wrong , grounding to battery is right .
post #8 of 11 (permalink) Old 02-10-2014, 06:32 PM
I grounded my amp to the fairing mounting bolt, 2 years and haven't had a problem. As for speakers, I had two sets of Polks mm651. And the DXI 650. After blowing out both sets I installed a set of Hertz speakers. They sound great and have not a any trouble with them blowing out!
HDFFR is offline
post #9 of 11 (permalink) Old 02-10-2014, 06:51 PM
What model Hertz did you get ?
post #10 of 11 (permalink) Old 02-12-2014, 09:32 PM Thread Starter
How are you guys mounting the PBR300?
came in yesterday. Got my wiring pulled from the battery, under the tank, and into the fairing. My local audio shop has said they use heavy duty adhesive Velcro to mount the PBR300 in the fairing.
Liquidr1 is offline
Yet another RF PBR300X2 and Infinity Kappa 62.11i Thread! Ganooch Audio 30 10-14-2015 07:36 PM
Mounting RF PBR300X2 Magnum Audio 13 05-10-2014 09:49 AM
Rockford Fosgate PBR300X2 Punch 300-Watt 2-Channel Boosted Rail Amplifier* Big_gary Audio 10 01-01-2014 05:36 PM
Any advice on install of RF PBR300X2? Hammerjsr20 Audio 2 09-01-2013 08:49 PM
Where to Buy RF PBR300X2? gfyoung3 Audio 15 04-27-2013 03:58 PM
