Help with main ground wire. - Road Glide Forums
post #1 of 16 (permalink) Old 02-10-2014, 06:53 PM Thread Starter
cruznmarine's Avatar
I'm installing my J&M Rokkers system. Everything going smooth until I got to the main ground for the amp. Instructions say NOT to go to neg post on battery, yet I have seen people do it even professional installers on YouTube. Only reason I ask I the main ground screw on the motor is pissing me off!!! I can't get to it. Is there a special tool I need?
I have a 2013 FLTRU
Thanks...
2017 Vivid Black Roadglide Special
~Semper Fi~
cruznmarine is offline
post #2 of 16 (permalink) Old 02-10-2014, 06:58 PM
sdlakerfan79's Avatar
I'm not sure about where the spot you're referring to, but the spot where I've ground my systems to is on the right hand side of the bike just forward and below the battery. If you want, I can take a picture of it and upload it. I forgot who told me about that spot, but i've used it on all my amps and it works like a charm. I cant remember what else is grounded there.
sdlakerfan79 is offline
post #3 of 16 (permalink) Old 02-10-2014, 07:06 PM Thread Starter
Would appreciate a pic. The main ground on the bike is behind the oils dipstick. Can't get any tools back there to get it. Some guys on the other HD forums said I could get background noise off the frame???
~Semper Fi~
post #4 of 16 (permalink) Old 02-10-2014, 07:10 PM
https://www.roadglide.org/showthread.php?t=116634 This guy FFR says he grounded to the fairing mounting bracket with out fail.
post #5 of 16 (permalink) Old 02-10-2014, 07:16 PM Thread Starter
Why are their so many opinions on whether or not to go directly to battery? Some companies say to, and others say never??? Is there some evidence either way of damage, or just personal beliefs/opinions?
~Semper Fi~
post #6 of 16 (permalink) Old 02-10-2014, 07:24 PM
Good question. I was wondering the same. I always thought there was no better ground than the battery.
post #7 of 16 (permalink) Old 02-10-2014, 07:26 PM Thread Starter
So confusing if your not specialized. I always thought it was ok unless your stacking it up.
~Semper Fi~
post #8 of 16 (permalink) Old 02-10-2014, 07:37 PM
Triplej's Avatar
Here is a good (short) explanation of a ground loop which may shed some light on the issue with noise caused from an improper ground.
http://www.carsdirect.com/aftermarke...-amps-overheat
Triplej is offline
post #9 of 16 (permalink) Old 02-10-2014, 08:22 PM
JayKS's Avatar
I don't buy the instruction that you have to ground the amp to the frame ground point rather than the battery. Those two points are on either end of a thick, short cable. Electrically, they're the same point.
I ground everything to a terminal block connected to the negative battery terminal and have had no problems.
On my last two bikes I've used a Powerlet Termin-8 to make all my positive and ground connections. It's convenient and maintains a single, clean connection to each battery terminal. Works great: http://www.powerlet.com/product/term...-fuseblock/409
Sent from Motorcycle.com App
JayKS is offline
post #10 of 16 (permalink) Old 02-10-2014, 10:07 PM Thread Starter
Sweet JayKS. Think that's what I will do.
~Semper Fi~
Info on main wire harness Q-Hog Controls & Handlebars 6 06-22-2014 01:37 PM
J&M Amp Ground Wire Help tsmartt Audio 6 05-29-2014 01:32 PM
Amp wire and ground point Venomized Audio 6 01-09-2014 11:07 PM
Removing Ground Wire from turn Signal Housing.. gpdstaffcapt *General Road Glide Discussions/Pictures 0 03-27-2013 10:56 AM
Ground wire? Willy_B Audio 2 05-16-2012 11:08 PM
