Parallel vs series speaker wiring? - Road Glide Forums
post #1 of 4 (permalink) Old 02-16-2014, 01:16 PM Thread Starter
madmat's Avatar
The more I read, the more confused I get. Bought a Hawg Wired Six Pack and Pioneer TS-C1644R speakers for the lower fairing. Finally have some time coming up to do the install. Parallel or series and why one way over the other?
Thanks Matt
18 RGS Bonneville Salt Pearl
madmat is offline
post #2 of 4 (permalink) Old 02-16-2014, 01:24 PM
caboverbob's Avatar
Here ya go
http://www.eminence.com/support/wiring-diagrams/
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
caboverbob is offline
post #3 of 4 (permalink) Old 02-16-2014, 07:38 PM
your amp and your speakers both have an impedance rating in ohms. They MUST match or you can damage your speakers, your amp or both, and you will not get optimum performance out of your system.
The simple rule is:
2 speakers wired in parallel - ohms are cut in half - i.e. 2 4 ohm speakers in parallel = 2 ohms impedance
2 speakers wired in series - ohms are doubled - i.e. 2 4 ohm speakers in series - 8 ohms impedance.
hope this helps
jrich4411 is offline
post #4 of 4 (permalink) Old 02-16-2014, 08:33 PM
StrokerAce's Avatar
Also make sure before you wire anything in 2 ohm that your amp can handle a 2 ohm load. Most amps will run 2 or 4 ohm but 4 ohm is much easier on your amp and produces less heat.
2009 Road Glide Vivid Black
StrokerAce is offline
Running speakers in parallel MyGlide Audio 9 03-15-2015 08:07 PM
Ohms and wiring (series v parallel) RedneckMedic66 Audio 7 03-30-2014 03:49 PM
Wiring in series to lowers question Emdog Audio 15 03-06-2013 01:56 PM
Limited Series - Vaquero Series Anyone? wachuko *General Road Glide Discussions/Pictures 6 04-11-2011 09:35 PM
