Two amps to battery - Road Glide Forums
 4Likes
post #1 of 17 (permalink) Old 02-22-2014, 09:02 PM Thread Starter
Two amps to battery
Ok guys and gals, I am wiring my two pbr amps to the battery and want to know how you did it. I am running out of room and wanting to see what y'all did. I have two eight gauge wires running down the neck and nowhere to put a fused dist. Block How and what did y'all do. Pics would be handy thanks Daniel.
texastrendz is offline
post #2 of 17 (permalink) Old 02-23-2014, 06:16 AM
Brewiz's Avatar
I just ran one from the battery to the fairing and into a power distribution block. You can get them for all sizes of wire and set ups.
Mike
sloride likes this.
Brewiz is offline
post #3 of 17 (permalink) Old 02-23-2014, 06:53 AM Thread Starter
Really want the fuses easily accessible, either under seat or side cover. I would think you would want it really close the battery just in case of a short or issue with amplifier so you do not melt every wire in the wire gutter.
BlueBagger12 likes this.
post #4 of 17 (permalink) Old 02-23-2014, 08:05 AM
Brewiz's Avatar
You can still have the fuse close to the battery. You run a small length of wire to a fuse holder under the seat or a side panel then out the the fairing where you mount the dist block then to the two amps.
I ran 8ga from the battery to the dist block then 10ga to my two amps with 10 ga ground wire to the fairing support. It's been like that for over a year and no problems.
sloride likes this.
Brewiz is offline
post #5 of 17 (permalink) Old 02-23-2014, 08:09 AM
I ran one 8 gauge wire to the fairing and have a distribution box there, I have 4 amps. My fuse is under the left side cover. Hope the pic helps.
Sent from my SPH-L710
post #6 of 17 (permalink) Old 02-23-2014, 08:19 AM
OKBigD's Avatar
I don't have abs so I have 2 fuses located where the abs module would be than I ran 2 8 gauge cables one to each amp that way if something happens hopefully only one amp quits.... I ran a third 8 gauge for ground to a lug on the amp mounting bracket for a common ground point.
OKBigD is offline
post #7 of 17 (permalink) Old 02-23-2014, 08:57 AM
Venomized's Avatar
My fuse is mounted in the left side cover too. Then it runs up the channel to the fairing. Im only running one amp but if I were running multiples Id have the fuse in the same place and the block in the fairing.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #8 of 17 (permalink) Old 02-23-2014, 04:31 PM Thread Starter
Thanks guys. I got it finally, had to make aluminum spacers to set it back a bit.
post #9 of 17 (permalink) Old 02-23-2014, 04:36 PM Thread Starter
Spacer shot. Works great. I used to different color cables so I would know which amp wire went to the fuse block.
sloride likes this.
post #10 of 17 (permalink) Old 02-23-2014, 04:58 PM
Q-Hog's Avatar
Nice job on the install..
Q-Hog is offline
Adding two Arc Audio Moto 600 amps QUESTION? bigshaqa Audio 6 02-19-2018 07:26 PM
Two Hawg Wired RS400 amps and more RichieRich Parts for Sale 19 06-10-2015 09:33 AM
Installed two amps radio stays on? Uncleford Audio 4 03-20-2014 08:49 PM
More than two amps! 09Sharknose Audio 18 10-29-2013 01:59 PM
Looking for two good battery chargers for the winter Cmathias Aftermarket Accessories 15 12-05-2011 11:58 AM
