Harley Amp - Road Glide Forums
post #1 of 8 (permalink) Old 02-23-2014, 10:42 AM Thread Starter
Harley Amp
2011 RGU is the Harley amp#76000169 worth buying . I have J&M speakers in the front Rockers . rear are Harley
Where can I buy the wire harness that comes with amp . The amp is used and he lost the harness. Dealer said that harness only available with new amp
hd2011 is offline
post #2 of 8 (permalink) Old 02-23-2014, 01:32 PM
What's the asking price, and what are the specs for the amp?
I just looked it up..... $400 for a 160 watt 40 watts per channel 4 channel amp. .... you can do a whole lot better, personally I wouldn't consider it, IJS..........
Sent from my SPH-L710
post #3 of 8 (permalink) Old 02-23-2014, 01:46 PM
ENG25TRK's Avatar
If you're talking about the rear speaker wiring harness, most dealers have those in stock for about $100. It connects to the HK in the rear to hook up the rear speakers and amp. When I had my HK, I didn't use it I just hooked up 4 wires to the proper locations in the rear of the HK. Then ran those to my amp. Worked just fine.
ENG25TRK is offline
post #4 of 8 (permalink) Old 02-23-2014, 02:55 PM
ERod62's Avatar
Yep go after market.
Sent from Motorcycle.com App
ERod62 is offline
post #5 of 8 (permalink) Old 02-24-2014, 06:08 AM
You'll do better with aftermarket and have a much easier install
racer-x is offline
post #6 of 8 (permalink) Old 02-24-2014, 07:42 AM
What he said. . . .
Gannicus is offline
post #7 of 8 (permalink) Old 02-25-2014, 06:50 PM Thread Starter
Only paying $100. plus $50. for dealer set up but need harness .what would be good after market amp. Thanks for the help
hd2011 is offline
post #8 of 8 (permalink) Old 02-25-2014, 07:20 PM
For less than $150 you could get a Sound Stream or Rockford PBR amp with twice the power of the HD amp.
Harley OEM 48 Amp Voltage Regulator & Stator bykw2 Parts for Sale 7 09-10-2018 03:06 PM
DETAILS - PA & MD (& VA & ??) Meet & Greet 2017 08Zinc Organize Rides Here 28 05-10-2017 01:50 PM
Brand new J & M ROKKER XT speakers in the box Djtman Parts for Sale 9 02-23-2016 02:27 PM
Harley Stage 1 CVO Aircleaner & K&N Easyryder01 Sold 14 07-06-2013 09:35 PM
Harley riders sue Harley skipperfltr General Off-Topic Discussions 43 09-15-2011 04:42 PM
