Newly installed Polk 6.5'a - Road Glide Forums
post #1 of 25 (permalink) Old 03-02-2014, 05:44 AM Thread Starter
BILBO's Avatar
I'm new to touring bikes, and bikes with stereos, so I'm completely lost when it comes to upgrading mobile audio. Please excuse my ignorance.BUT.... I recently installed some speakers (no aMP at this time) I soldered the connections, GOT EVERYTHING put back together after listening to then to "make sure" the connections were good... But when I went for a test ride, the sound coming from the speakers sounded like it was being played on a record. There was piping and cracking (like static). The ironic thing is, it only happens while riding. Never when it's just sitting there...
Any opinions on what I need to do... Check?
I'm not ANYWHERE familiar with mobile audio, as I am with Home Audio...
Any help would be Greatly Appreciated!
Jay
BILBO is offline
post #2 of 25 (permalink) Old 03-02-2014, 06:15 AM
Venomized's Avatar
Whats the speaker model? What source are you using (CD/AUX/RADIO)? Did you ceck your connections to make sure theyre correct polarity and not loose? Youll get a "hallway effect" if ones correct polarity and the others not. The static sound could be a loose coonection.
If all you changed was speakers then the speakers have to be the culprit.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #3 of 25 (permalink) Old 03-02-2014, 07:50 AM
+1 with the check connections and polarity. I have the stock radio, polk 6.5 and no amp and its a vast improvement over the stock speakers. I can hear clearly up to about 80mph. Granted its not as good as it could be with an amp but definately better than stock speakers
post #4 of 25 (permalink) Old 03-02-2014, 09:05 AM Thread Starter
BILBO's Avatar
DXI 650
BILBO is offline
post #5 of 25 (permalink) Old 03-02-2014, 09:15 AM Thread Starter
BILBO's Avatar
It doesn't matfer if I listen to Radio,CD, Aux, via Bluetooth for Music off of my phone.... I KNOW the connections are secure....on the speaker end, but I extended the wires and butt connected at that point.
The speakers are ALL that I changed...
My question is.... Why does it only have "static and popping sounds" with riding..... If it were "wrong" shouldn't it do it ALL of the time.... If all I do is turn the switch on, and listen to radio, cd, our aux... It doesn't make the sound....
Stock head unit
No amp
BILBO is offline
post #6 of 25 (permalink) Old 03-02-2014, 12:51 PM
Originally Posted by BILBO View Post
DXI 650
These are 4 ohm speakers and depending on the year of your Bike the Harley system is 2 ohm. You will need to get an amp to run these speakers or change the speakers to the Polk MM651 model. These are 2.7 Ohms. The Rockford Fosgate PBR300X2 would be a great start with either speaker. To fully enjoy your speakers at speed you will need an amp. The HK unit doesn't have a strong enough signal to push 4 ohm speakers.
Gannicus is offline
post #7 of 25 (permalink) Old 03-02-2014, 12:55 PM Thread Starter
BILBO's Avatar
My bike is an'03 with stock HK Head Unit.
Thanks for the info..
BILBO is offline
post #8 of 25 (permalink) Old 03-02-2014, 01:05 PM
Not completely sure if the 03 system is 2 ohm or 4 ohm. I'd give Tony a call at Iron cross audio tomorrow he would know for sure. http://www.ironcrossaudio.com
Gannicus is offline
post #9 of 25 (permalink) Old 03-02-2014, 05:08 PM
Venomized's Avatar
Wont matter if theyre 4 ohm or 2 ohm. The reason its doing it only while riding is that at one of your points of connection its loose. Its losing connection with the vibration of the bike.
'07 Pewter Pearl
post #10 of 25 (permalink) Old 03-02-2014, 05:19 PM
I agree, the OP said he used butt connectors to extend the wires, that's the first place I'd be looking.
Sent from my SPH-L710
Newly aquainted to no red sunglasses piggs *General Road Glide Discussions/Pictures 4 07-08-2013 09:38 AM
My Newly Painted Mean Mug Bezel Andyman Aftermarket Accessories 17 05-02-2013 06:28 PM
Newly installed 13" Windvest dgfltru Windshields 3 07-24-2012 08:46 PM
2011 CVO RG has newly designed handlebars DED HD Controls & Handlebars 2 08-16-2010 03:54 PM
