Help needed!!...static.. - Road Glide Forums
post #1 of 8 (permalink) Old 03-03-2014, 04:09 PM Thread Starter
Posted on another forum and no response so maybe someone here can help.
Have done the whole stereo upgrade to my '11RGC. Sony head-unit, RFamp, 6 speakers etc. What is happening tho when I power off the bike at the ignition, whether radio is on or not, I get a 'hiss' of static through all of the speakers for about 3-4 secs and then the usual Sony chime. I have the Biketronics module and have to constatly reset it which is beginning to be a pain. I can be riding and the volume increases on its own, or the head-unit turns itself on all by itself. So, the static...any ideas?? Im at a loss. Thanks in advance.
UltraDune is offline
post #2 of 8 (permalink) Old 03-03-2014, 04:31 PM
I have a Sony..... what chime are you referring to? Are you having the amp turned on remotely, or by the input level? Almost sounds like you may need to adjust the AVC on the Biketronics unit also. Hopefully someone with the Biketronic unit will chime in soon. I have the Hawgwired and am not to familiar with yours.
Sent from my SPH-L710
post #3 of 8 (permalink) Old 03-03-2014, 05:09 PM
Gray Beard
lundboy1's Avatar
The sony in my truck has a beep boop beep boop tone when I shut the truck off. I think it's the reminder you left the detachable face on ... As far as the static goes have you tried shouting the radio off / leaving the ignition switch on? If the results are the same could be a signal being carried through amp as it shuts down?
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #4 of 8 (permalink) Old 03-03-2014, 11:07 PM
glide1's Avatar
Sounds like a bad or loose ground somewhere.
glide1 is offline
post #5 of 8 (permalink) Old 03-04-2014, 05:56 AM
Neano62's Avatar
Didnt check ur Profile, but did u change bars and are wires ran internal???
Problem could be there, with a wire or two,...
otherwise it could be a ground on one of the components u've installed. Ground wires can give you fits!
If neither or are the problem, sounds like a defective component.
Ive got a Sony on mine and I can turn the Bing-Bong Churps off.
But the static thing,.... reground ur amp, then have biketronics check that module.
[/IMG]
Neano62 is offline
post #6 of 8 (permalink) Old 03-04-2014, 07:31 AM Thread Starter
Thanks for the replys. Will pull the nose again and check all connections and ground. Yah, my Sony does the beep beep thing on shut down. From what I understand you cant turn it off. Thanks again!!
post #7 of 8 (permalink) Old 03-04-2014, 09:51 AM
Depending on what model & yr Sony you have, you can turn off the the faceplate reminder.
See if this works:
1.Press and hold the Select button until the Setup Display appears.
2.Rotate the Control Dial until CAUT ALM displays, then press the Select button.
3.Rotate the Control dial to select OFF, then press the Select button.
4.Press the BACK button to exit the menu
post #8 of 8 (permalink) Old 03-05-2014, 06:14 AM Thread Starter
Awesome...thanks! The faceplate chime was driving me crazy.
Static in radio after Daymaker install litespeed Lighting 0 07-21-2013 07:54 PM
Speaker vibration, Static TC308 Audio 14 07-14-2013 10:28 PM
Speaker vibration or static TC308 Troubleshooting for Road Glides 0 06-20-2013 06:29 PM
Speaker vibration or static TC308 Troubleshooting for Road Glides 0 06-20-2013 06:16 PM
Static or white noise METIME Audio 7 04-23-2011 01:28 PM
