PBR300X2 - another question - Road Glide Forums
post #1 of 3 (permalink) Old 03-03-2014, 06:20 PM Thread Starter
Goblyn's Avatar
Can I drive more then one set of speakers with a 300X2? I've read that you can wire the speakers in series/parallel and you maintain the ohms? But has anyone out there pushed the Rockford amp and had success? Thanks!
2010 FLTRX Denim Black - 120R, V&H Pro Pipe 2 into 1 wrapped, SE Super Tuner, SE Heavy Breather, Progressive Monotubes w/2" drop, LA Choppers 1" lowering blocks, Custom Gauges and LED Mod, Super Lizard Maximus Kit - just starting!
Goblyn is offline
post #2 of 3 (permalink) Old 03-03-2014, 06:54 PM
It can be done, I had two sets of 4ohm speakers wired to mine when I had it. (4ohms parallel = 2ohms) Just make sure you match the impedance, if not remember the speakers having a higher impedance than the amp won't hurt you, lower and you're asking for problems.
Sent from my SPH-L710
post #3 of 3 (permalink) Old 03-04-2014, 02:32 PM
pacmanrr's Avatar
Im running two sets of Polk Audio dxi 650s off of one PBR 300x2. Just wire them in parallel and you are good to go like dbell stated.
pacmanrr is offline
PBR300x2 question rustyj671 Audio 3 07-04-2016 08:40 PM
Total Noob Rushmore PBR300x2 and Kappa Install Question... padwell88 Audio 6 02-28-2016 07:57 AM
Yet another RF PBR300X2 and Infinity Kappa 62.11i Thread! Ganooch Audio 30 10-14-2015 07:36 PM
rockford pbr300x2 question on wiring suicidecj5 Audio 12 07-02-2015 11:02 AM
Looking for PBR300X2 in Houston Tx. Duke1906 Audio 4 04-15-2012 08:35 AM
