Any chance to mount SS amp on top of headunit? - Road Glide Forums
post #1 of 10 (permalink) Old 03-12-2014, 06:59 AM Thread Starter
hometoast's Avatar
Anyone mount their PN2.350D on top of their headunit like I've seen some folks do with the PBR amp?
I'm not real keen on my fabricating skills to make a bracket -- don't get me wrong, I'll do that if I have to, but it'll be ugly!
hometoast is offline
post #2 of 10 (permalink) Old 03-12-2014, 09:15 AM
kouack's Avatar
Even if its ugly no body will see it ;-)
kouack is offline
post #3 of 10 (permalink) Old 03-12-2014, 09:21 AM
Venomized's Avatar
If you dont mount it there, the side of the inner with velcros an option.Thats what i did and many others have as well with our SS amps.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #4 of 10 (permalink) Old 03-12-2014, 09:54 AM Thread Starter
hometoast's Avatar
I'll try that. I have some strips of Duo-Lock somewhere I could try.
But I would! I was less worried about ugly than I would be about making it "right"
post #5 of 10 (permalink) Old 03-24-2014, 09:00 AM Thread Starter
hometoast's Avatar
BTW - I went the velcro route. I didnt' have enough of that duo lock stuff, so just some plain old 'industrial' strength velcro and it's secured pretty darn well.
the amp "could" fit over the head unit, but its such a squeeze, and would be hard to remove to service that it wasn't worth it.
post #6 of 10 (permalink) Old 04-16-2014, 11:53 AM
Does anyone have any pics of it Velcro by the glove box? Looks like the wiring would be tight in the corner behind the glove box. I'm using the ss 4520d if it makes a difference
rgu11 is offline
post #7 of 10 (permalink) Old 04-18-2014, 01:25 PM
Venomized's Avatar
I do!
'07 Pewter Pearl
post #8 of 10 (permalink) Old 04-18-2014, 01:32 PM
Ebrown's Avatar
no pics, but I did mount my 4.520 with industrial Velcro on the inner fairing between glove box on right side of bike, it is tight, but works. had to angle it up in the front a bit to clear the outer fairing, with the gain controls to the front. pretty convenient, I can get in to adjust the gains just by taking out the right headlight instead of removing entire fairing.
'12 FLTRU Big Blue Pearl, Zippers Max Flow AC, modified V&H slash cut slip ons, Windsplitter, addin' one thing at a time...
Ebrown is offline
post #9 of 10 (permalink) Old 04-18-2014, 01:41 PM
faststan's Avatar
Check out h-donut's thread.
https://www.roadglide.org/showthread....ht=AMP+BRACKET
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #10 of 10 (permalink) Old 04-21-2014, 07:53 AM Thread Starter
hometoast's Avatar
I do!
I did the exact same. with a 320d, so I didn't have to angle it up. It fit well. It's definitely not going ANYWHERE... it takes a lot to pull it our because you have to kind of pull it down across the velcro surface.
2013 Candy Orange FLTRX
Ss pn4.520d VS ss st4.1000d sjohn1024 Audio 9 02-27-2016 09:35 PM
Trouble with install of kenwood headunit and kenwood amp. Shuts off... Mikie Audio 0 08-03-2015 11:24 AM
Picked the speakers and Headunit..... What Amp????? Ugly ego Audio 6 07-24-2013 12:35 PM
ss push rod keepers not going to top cestaro Engine Related 0 06-03-2012 03:24 AM
Top mount vs bottom mount in fairing? SickRick Audio 5 12-30-2011 01:28 PM
