Audio help - Road Glide Forums
post #1 of 11 (permalink) Old 03-19-2014, 01:04 PM Thread Starter
zombie's Avatar
Audio help
Need some help,
2009 Road Glide
stock head unit
J&M 2 ohm in factory location
Pioneer 6" 4ohm cut out in lower fairing.
Had dealer put front and rear phase on Head unit
so I can run sound up top to J&M, or down below to Pioneer.
I want to add an amp on the cheap, just for better sound.
looking at the rockford pbr300x4
can I run the J&M 2 ohm along with the 6" 4 ohm .
or do I buy rockford pbr300x4 along with some new 6" 2 ohm speakers?
Thanks.
2009 FLTR, in the works, FM 107, 777cams, Jackpot Header, Power Vision,K&N high flow, 1" drop back, 12" windvest, K&N slip ons, 14" black apes, tri light , vented lowers ,misc..
zombie is offline
post #2 of 11 (permalink) Old 03-19-2014, 01:12 PM
Sound Stream has a 4 channel 2 ohm stable amp that's about the same price, better amp IMO.............IJS.......
post #3 of 11 (permalink) Old 03-19-2014, 01:18 PM
Venomized's Avatar
+1 on soundstream amps
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #4 of 11 (permalink) Old 03-19-2014, 02:39 PM Thread Starter
zombie's Avatar
what model # is the Sound Stream, and do I keep the 6" 4 ohms or junk and get what?
zombie is offline
post #5 of 11 (permalink) Old 03-19-2014, 02:46 PM
Venomized's Avatar
PN4.520 and you can run the 6" if you want or get something else. Your choice
'07 Pewter Pearl
post #6 of 11 (permalink) Old 03-19-2014, 03:36 PM
Willy_B's Avatar
You can only run 4 ohm speakers with the pbr300x4. It is not 2 ohm stable.
Willy_B is offline
post #7 of 11 (permalink) Old 03-19-2014, 04:29 PM
Eshaw301's Avatar
Soundstream has multiple options for our bike. In addition to the PN4.520, check out the TN4.900. Its double the price, but it puts out 150 watts RMS per channel and thats at 4 ohms!!! I ordered mine yesterday because I too have the J&M amp and its just not putting out enough per channel (even in parallel dropping speakers down to 2 ohms) to get the most out of these pioneers.
"DUDE!...Your exhaust is making the ground shake!" Circa March 2014, Born Losers MC, Atlanta.
Eshaw301 is offline
post #8 of 11 (permalink) Old 04-01-2014, 05:26 PM Thread Starter
zombie's Avatar
Where is the best place to mount the Soundstream TN4.900D?
I'm concerned that I can't fit on side of glove box since I have my 6"s mounted there already.
Looks like people like the amp, and I can run 2 & 4 ohm at same time.
Thanks.
zombie is offline
post #9 of 11 (permalink) Old 04-01-2014, 07:23 PM Thread Starter
zombie's Avatar
Also, any pictures on mounting would be great.
zombie is offline
post #10 of 11 (permalink) Old 04-01-2014, 08:58 PM
Thanks.
The TN4.900D won't fit on a roadie or batwing. . . .You would have to mount it in the saddlebag.
Gannicus is offline
Aquatic AV-JL Audio HX280/4-Polk Audio MM652s, SMD DD1 rustyj671 Audio 6 08-22-2017 02:49 PM
Car audio vs motorcycle audio sdlakerfan79 Audio 20 04-11-2013 06:52 PM
Arc Audio Speaker Adapter Install Help PC PaiN Audio 9 11-28-2011 05:22 PM
Audio help jimmyray11349 Audio 8 11-06-2011 08:15 PM
Audio help> JOHN103 Troubleshooting for Road Glides 4 05-29-2010 08:00 PM
