Decisions decisions - Road Glide Forums
post #1 of 12 (permalink) Old 03-20-2014, 07:42 AM Thread Starter
Decisions decisions
Been reading a lot on the forums for a good system for my wife and I. I'm leaning towards fairing and lowers for us with a 4 channel amp. Can't decide whether to go with J&M roller xx's for both with the tweeter grills, or polk Audi 651mm for both. Price wise won't be much of a difference once you factor in the adapters, speaker boxes and grills needed for the polks. Also torn between J&M 500w 4 channel or soundstreams Pn4.520. The soundstreams is exceptionally cheaper, but I'm not sure on the wiring required to make it work versus J&M plug n play system. Any feedback or suggestions is greatly appreciated.
rgu11 is offline
post #2 of 12 (permalink) Old 03-20-2014, 08:46 AM
Eshaw301's Avatar
The wiring can easily be figured out. You will have to go with an aftermarket stereo or send your HK head unit out to get RCA installed. Thats the only way to make it super simple (it's already simple enough. I posted this in another thread. Best bet if you ask me....
1. Soundstream TN4.900D (you will need it for what I am about to throw at you) $200
2. Two pair of Pioneer TS-D6902R (ultimate bass and get them mounted in your bags) $140
3. J&M Rokker HTWT-1025-CRF tweeter kit (replaces two gauges in the fairing like the CVOs) $120.
4. One pair of Infinity 62.11i (for better highs) $120 OR......
5. One pair of Pioneer TS-D1702r (for more bass) $66
All of these can be had on Amazon (search the part numbers I posted).
"DUDE!...Your exhaust is making the ground shake!" Circa March 2014, Born Losers MC, Atlanta.
Eshaw301 is offline
post #3 of 12 (permalink) Old 03-20-2014, 10:59 AM Thread Starter
Is it necessary to have the rca's for the amp wiring, or can you use the front speaker wiring? Does anyone make wiring harnesses for aftermarket amps or are they amp specific?
rgu11 is offline
post #4 of 12 (permalink) Old 03-20-2014, 11:36 AM
Are you running the stock HU or aftermarket?
Gannicus is offline
post #5 of 12 (permalink) Old 03-20-2014, 12:23 PM
Eshaw301's Avatar
It is possible to use the speaker output wires to send signal to the amp. I am not understanding about wiring harness for amp. It's pretty straightforward when hoking one up. The confusion comes with setting gains and making all the adjustments. But even that can be learned by a novice.
Eshaw301 is offline
post #6 of 12 (permalink) Old 03-20-2014, 12:33 PM Thread Starter
Using the stock hu
rgu11 is offline
post #7 of 12 (permalink) Old 03-20-2014, 12:42 PM
Not absolutely necessary, but the improvement in sound quality is Amazing!
After a lot of research, I went with the J&M Rokkers/XTs in the fairing/lowers, J&M Rokker 500w in the fairing, HK w/ Iron Cross Audio preamp outs.
Clean, clear music at 90+!!! (about 3/4 volume!)
HeatWave is offline
post #8 of 12 (permalink) Old 03-20-2014, 02:49 PM
Using the stock hu
RCA's not necessary on the stocker but as Heatwave said big difference in sound quality. . . .Just use the speaker wires to the input side of the amp or if you want to go low level a lot of guys just send the stock HU to Iron cross and get it modified like heatwave did above. He sounds like a happy camper!
Gannicus is offline
post #9 of 12 (permalink) Old 03-21-2014, 08:46 AM Thread Starter
Leaning towards J&M speakers and the SS amp. Are the rokker xx worth the extra money over the performance series?
rgu11 is offline
post #10 of 12 (permalink) Old 03-21-2014, 10:19 AM
Sounds like your on the right track . . .Eshaw301 loves his rokkers! Just depends on what you listen to. Are they worth the extra cash? Who knows? You would have to do a side by side apples to apples comparison , same amps, same number of speakers etc., Even then 5 different guys would have 5 different opinions. Get what sounds good to you!
Gannicus is offline
decisions decisions Road08Glide *General Road Glide Discussions/Pictures 6 03-25-2013 12:13 PM
Decisions, decisions... Ultra v. Custom BigSpenda864 *General Road Glide Discussions/Pictures 66 02-22-2013 02:44 AM
Decisions Decisions scayne62 *General Road Glide Discussions/Pictures 28 01-23-2013 08:04 AM
Decisions, decisions... crayon *General Road Glide Discussions/Pictures 17 07-30-2012 08:28 PM
Decisions, decisions! mandlbarrett Controls & Handlebars 11 06-28-2012 08:01 PM
