Installed two amps radio stays on? - Road Glide Forums
post #1 of 5 (permalink) Old 03-20-2014, 01:49 PM Thread Starter
Hey guys, a while back I installed the Hog Wired amp kit with 6.5" speakers. System worked great and sounded good. TLater I installed the Polk audio 6.5" speakers in the inner fairing, driving them with the same Hog Wired amp. Sounded much better, really happy with the whole set-up. Then I decided I needed more sound...so I added a Rockford Fosgate amp (300x2) to run the inner fairing speakers. I had to go to HD and pick up a few parts (pt# 69200033 and 2 additional pins 74xxx) to run the amp and speakers when hooking it up to the 35 pin radio connector.
Now the radio will turn on and everything works great (sounds great!) but when I shut the bike off the radio and HW stay on. I checked over all the wiring, it all looks good.
I wound up pulling the remote wire from the cigarette lighter and everything is now normal. The radio and both amps shut off. Why is this? I never had a problem with the HW amp remote wire hooked to the cigarette lighter but when I added the RF amp in line with it the radio stayed on. Has anyone else run into this issue? What am I missing here. Thanks!
'11 RG - Vivid Blk -S&S 106, Dragula 2-1, Drago 580 cams, Drago Stg II Heads, PM Fast Air, PCV with Auto Tune, R6 14.5" bars, DIY Monroe Air Ride.
Uncleford is offline
post #2 of 5 (permalink) Old 03-20-2014, 02:47 PM
Venomized's Avatar
Cause the RF amp uses the signal from the hi level inputs to sense that it needs to turn on. Basically you were giving it a constant power supply until the capacitors in the RF amp discharged by using the cigarette lighter to the remote turn on of the amp. You dont need a remote signal with the RF amp.
'07 Pewter Pearl
Road Glide or No Ride!
Venomized is offline
post #3 of 5 (permalink) Old 03-20-2014, 03:00 PM Thread Starter
Okay, I will buy that. Neither amp has a remote wire hooked up now and they both come on when the bike is switched to on. Thanks, just trying to make sure before I button it all back up.
post #4 of 5 (permalink) Old 03-20-2014, 03:57 PM
PGR
PGR's Avatar
If you pulled the remote off of the lighter and everything works correctly now......Check the polarity of the cig lighter with a meter or test light. It's possible your lighter is wired backwards, and you were supplying a constant ground.
Ron..........................
PGR is offline
post #5 of 5 (permalink) Old 03-20-2014, 08:49 PM Thread Starter
Ok, I will check
Adding two Arc Audio Moto 600 amps QUESTION? bigshaqa Audio 6 02-19-2018 07:26 PM
Two amps to battery texastrendz Audio 16 09-20-2016 10:03 PM
Two Hawg Wired RS400 amps and more RichieRich Parts for Sale 19 06-10-2015 09:33 AM
More than two amps! 09Sharknose Audio 18 10-29-2013 01:59 PM
Radio back ground light stays on RoadGlide0611 Troubleshooting for Road Glides 1 10-22-2012 07:07 AM
