Broken "Audio" button - Road Glide Forums
post #1 of 21 (permalink) Old 03-23-2014, 10:07 PM Thread Starter
Sent from Motorcycle.com App
Throwing my leg up and over my RG earlier today I kicked the Audio button. It went flying. Came out of the switch pod with a piece of brass connected to it. Broken piece of black plastic too.
What all is involved in replacing this button?
Thanks in advance...
Slyguy41 is offline
post #2 of 21 (permalink) Old 03-24-2014, 01:06 AM
Banned
U kicked ur audio button as u were getting on???! Are u a freakin ninja? How in the world does that happen? Did u jump off something, say a two story house to mount it? Lmao man, sorry no help but I would certainly look into rethinking my mounting technique if I was you
Scootin is offline
post #3 of 21 (permalink) Old 03-24-2014, 02:44 AM
torqu's Avatar
Dealer should have them with the brass shim. $6 if I recall
torqu is offline
post #4 of 21 (permalink) Old 03-24-2014, 08:38 AM
Eshaw301's Avatar
Originally Posted by Scootin View Post
U kicked ur audio button as u were getting on???! Are u a freakin ninja? How in the world does that happen? Did u jump off something, say a two story house to mount it? Lmao man, sorry no help but I would certainly look into rethinking my mounting technique if I was you...
LMFAO!!!! Im sorry too...I just got an idea in my head as I read the original post and then I see your response. You hit the nail on the head with this one because I was thinking to myself....how in the hell do you mount your bike and kick the audio button off your handlebar?!!! I know I offer no help or remedy on this one...but this thread just made my day!
"DUDE!...Your exhaust is making the ground shake!" Circa March 2014, Born Losers MC, Atlanta.
Eshaw301 is offline
post #5 of 21 (permalink) Old 03-24-2014, 08:43 AM
OKBigD's Avatar
I swapped my switch housings to the chrome ones and those switches are a pita to get back in perfectly.... from what I remember they are wired all the way through... so if your wired internally you'll have to remove the wiring harness or cut and splice...... not much room inside those pods.....
OKBigD is offline
post #6 of 21 (permalink) Old 03-24-2014, 09:15 AM
Don't try and repair just replace, the parts guys' will tell ya all, about as easy as changing grips. Just don't get any water in any switch housing
reds4 is offline
post #7 of 21 (permalink) Old 03-24-2014, 09:33 AM
I have repaired my audio button a couple of times. The brass peg goes through a plastic face plate and it will go back into the main switch, you can see where the peg goes and as long as you put the faceplate on while keeping the peg straight the switch will go back together alright. If the complete faceplate came off you can just super glue the switch back together and everything will work fine. If you broke the faceplate you may not be able to repair the switch.
HD just glues these switches together and the glue can fail over time just from age and getting the switch wet from riding in the rain or washing the bike and heat may have something to do with it too.
post #8 of 21 (permalink) Old 03-24-2014, 10:00 AM
Mark62's Avatar
Post
I 2nd that "Are you a freaking Ninja"?
2013 RGU Vivid Black / SE 204 Cams / SE Heavy Breather / SE Super Tuner / Most chrome PC Blk / Reinhart Black slip ons / Black Ice Wheels / De-Cat Header / Pow-Mia Theme in remembrance of my Papa Joe, U.S.S Houston.
Mark62 is offline
post #9 of 21 (permalink) Old 03-24-2014, 08:44 PM
Banned
Hahahaha, so funny!!!
On a serious note: i tried to mount my bike and kick the audio button, absolutely could not do it. Then I decided " well, screw it, Ill just try and kick it" ...... i couldnt even kick it, let alone mount and kick it!! Man, please make a video of how you mount this bike and let us try and help you prefect your mounting technique!!
Scootin is offline
post #10 of 21 (permalink) Old 03-24-2014, 10:24 PM Thread Starter
Pretty easy when you think about it guys.
Handlebars cocked hard to the left. Lift your right foot up to clear the tank.
The toe of your boot can hit the switch.
Seriously. That's not the point
Slyguy41 is offline
Broken Speaker Mounts DAK47 Audio 14 06-15-2014 07:25 PM
Wanted left side audio button (blk) Dmize Wanted! (Buy or Trade) 10 05-06-2013 08:23 PM
did I break an audio button? Dmize Audio 3 12-31-2012 07:08 PM
Broken Heat Sheild (need advice) newtome Intake and Exhaust 2 06-10-2011 05:28 PM
