Amp selection - Road Glide Forums
post #1 of 8 (permalink) Old 03-25-2014, 09:29 PM Thread Starter
MN_Rider's Avatar
Amp selection
My PBR300X2 amp order got cancelled by vendor. I am taking this as a sign I should reconsider my options. Other amps I was considering was the Soundstream PN4.520 or the PN4.320. Also considering the Alpine MRV-F300. This will power a pair of Focal 165 AC in stock location.
SS gets a lot of praise by some of you but I worry about losing FM reception. What is that caused by? Anything I can do to fix or prevent it? Is the PN4.520 overkill for the 165 AC?
Anyone have experience with the Alpine MRV-F300? It is 8" x 8" x 2". Will this fit in the fairing?
MN
MN_Rider is offline
post #2 of 8 (permalink) Old 03-29-2014, 06:30 PM Thread Starter
MN_Rider's Avatar
Anybody running the JL JX360/2? Of the four listed in this post (Alpine MRV F300, RF PBR 300x2, JL JX360/2, or the Soundstream PN2.350) which one would you recommend to run a pair of Focal 165 AC?
MN
MN_Rider is offline
post #3 of 8 (permalink) Old 03-29-2014, 06:38 PM
NorCal's Avatar
with my Focal 165's I'm running the Arc Audio KS125.2 and am pleased.
NorCal is offline
post #4 of 8 (permalink) Old 03-29-2014, 06:57 PM
With the Sound Stream you don't loose the FM, it can interfere with it, just as any class D amp which is most of the amps out there for MC's, my Hawgwired amps gave me some interference also, I hooked up a filter and have been good to go since. Also if you're only using one amp and mount it in a similar position to where Nor Cal has his amp mounted, you shouldn't have much of a problem.
post #5 of 8 (permalink) Old 03-29-2014, 10:33 PM Thread Starter
MN_Rider's Avatar
Norcal - very clean install. Nice.
Dbell - that is the same location I plan to mount. Leaning toward the JL JX360/2.
MN
MN_Rider is offline
post #6 of 8 (permalink) Old 03-29-2014, 11:25 PM
Q-Hog's Avatar
Look at all the bright colors.. clean install you got there.
Q-Hog is offline
post #7 of 8 (permalink) Old 03-30-2014, 11:06 AM
Q-Hog's Avatar
I use JL amps, but a friend of mine have a kenwood xr400-4 that has the same specs as the JL
Xd4/400 but can fit in the inner fairing. I'm thinking of switching.
Q-Hog is offline
post #8 of 8 (permalink) Old 02-09-2016, 11:28 AM
useful post, thanks for the info!
hunt85 is offline
Wheel size selection? JKRSDETROIT Wheels and Tires 53 01-11-2014 12:48 PM
Need a lil guidance and info on amp selection Taccone Audio 12 08-31-2013 08:18 AM
Tire selection information/advice for New SERG owner. Phantom6722 Wheels and Tires 8 06-06-2012 09:02 PM
Need help with wheel selection Sincecrazy *General Road Glide Discussions/Pictures 14 12-12-2010 09:20 AM
