Ohms and wiring (series v parallel) - Road Glide Forums
post #1 of 8 (permalink) Old 03-27-2014, 05:29 PM Thread Starter
RedneckMedic66's Avatar
Well in the search for knowledge on all this audio stuff with everything from watts and ohms to types of wiring and component v coaxial and RCA input v high level from speaker wires my head has been hurting. So I've been doing a little research here and there prior to my audio install. After looking at wiring diagrams I finally figured some things out but then found this site and for some reason after reading this it kinda clicked for me. Just figured I would pass this on.
https://www.termpro.com/asp/pubs.asp?ID=124
So I figured if any one else has any good reference links to post them here.
GLIDE OR DIE!!
RedneckMedic66 is offline
post #2 of 8 (permalink) Old 03-27-2014, 06:54 PM
stripclub's Avatar
Nice find. A lot of good information.
stripclub is offline
post #3 of 8 (permalink) Old 03-29-2014, 11:35 AM
Steelcity's Avatar
Great post needs to be a sticky
Steelcity is offline
post #4 of 8 (permalink) Old 03-29-2014, 12:04 PM
Dmize's Avatar
This site helped me allot... figuring out stuff... nice because you can plug in your speaker / amp ratings and you can see how things change.
http://www.bcae1.com/spkrmlti.htm
D.
D.Mize
16 CVO RGU
Dmize is offline
post #5 of 8 (permalink) Old 03-29-2014, 01:04 PM
Big Daddy Recon's Avatar
D.
thats a great site I use it all the time...lots of good knowledge there
2008 Harley FLHTCUI (MABLE) 50k+)
2011 Harley FXDWG (TRADED) 10K miles)
2013 Harley FLTRX (LUCIFER)(DECEASED) last 3 of VIN = 666
Big Daddy Recon is offline
post #6 of 8 (permalink) Old 03-29-2014, 01:43 PM Thread Starter
D.
Good info there too
GLIDE OR DIE!!
post #7 of 8 (permalink) Old 03-29-2014, 01:59 PM
Q-Hog's Avatar
Good info.
Q-Hog is offline
post #8 of 8 (permalink) Old 03-30-2014, 03:49 PM
Here is my contribution to this thread called "How loud will it go"
This is for the guys who are having trouble hearing their 6 x 9's at speed.
This calculator shows:
Sensitivity
Amp Power
No. of speakers
If you plug your specs in the calculator will show you how loud your speakers are at a specific distance.
To hear your lids at speed I've found your specs need to be around 105 DB or higher.
Check it out and enjoy!
http://myhometheater.homestead.com/splcalculator.html
Gannicus is offline
4 ohms - 2 ohms T-BO 399 Audio 4 07-10-2015 10:47 PM
Running speakers in parallel MyGlide Audio 9 03-15-2015 08:07 PM
Parallel vs series speaker wiring? madmat Audio 3 02-16-2014 08:33 PM
? About ohms Willy_B Audio 14 04-09-2012 06:40 AM
