Inner fairing speaker question - Road Glide Forums
post #1 of 10 (permalink) Old 03-30-2014, 03:50 PM Thread Starter
sharknose10's Avatar
I installed a 149BT with a hog wired six pack. I want to add a set of Infinity Kappa 62.11i to the inner fairing. Will I be able to run all 4 speakers off my HW amp if I wire the speakers in parallel? Is anyone running this setup and if so how does it sound? Thank you.
2010 RGC, 21/17 Wanaryd, Top Shop bags, fender,side covers, Dragula 2, Ness Legs, PM mirrors, SE heavy breather, Alpine 149BT, 4 Hertz 165.1, Hertz ST 25, CVO lids with Hertz 6x9ís, powered by Micro 4 amps, Battistinis boards, Vindikta 12" bars.
sharknose10 is offline
post #2 of 10 (permalink) Old 04-01-2014, 01:24 PM
I have the same question and idea for doing this on my 09. Slider 57 did something similar on his thread. He added extra fairing speakers to an Ultra so he already had a 4 channel system and added the 2 channel amp. He mentioned wiring in parallel but lost me partway through.
Other companies talk about 2 versus 4 channel amps I DO NOT want to got to go to the HD dealer to have my HK system 'reflashed' or what ever to 4 channel. I also see mention of guys using other amps (not part of a kit) for much less money but I'm assuming they are doing all their own wiring. I want "caveman" plug and play.
Any comments anyone?
kuuud is offline
post #3 of 10 (permalink) Old 04-01-2014, 01:38 PM
Depending on which Hawgwired amp you have, it's only going to be 2ohm stable if it's not an older 4 ohm system, if it's an older or newer amp, the answer is no, you shouldn't run the speakers parallel, your amp will heat pretty fast and probably not last to long, especially at volume. I faced this same problem with my rear and that's the only reason I don't run Infinity's back there. I would suggest you buy another amp, or if your speakers are 4 ohm, buy another set of 4 ohm and put them in parallel, (that's if you have a 2 ohm stable amp).
post #4 of 10 (permalink) Old 04-01-2014, 02:10 PM
Eshaw301's Avatar
Yes. Your amp is 2 ohm stable. The kappas are two ohm. The other speakers are 4 ohm. Running in parallel makes the amp draw 3 ohms, which is in the safe zone. I have never heard hawg wired speakers so I cant tell you how they sound. I have heard the kappas and they are LOUD AND CLEAR! I have yet to hear anything close to those kappas on a bike. But, like I said before, I have never heard the hawg wired. Even if I had heard them, the price alone puts them out of the league of the kappas.
"DUDE!...Your exhaust is making the ground shake!" Circa March 2014, Born Losers MC, Atlanta.
Eshaw301 is offline
post #5 of 10 (permalink) Old 04-03-2014, 09:00 AM
CNMTurner's Avatar
You might want to check your calculations.. Running two 4 ohms speakers in Parallel results in 2 ohms load on the amp.. Running two 2 ohms speakers in parallel results in a 1 ohm load. Mixing 2 ohms and 4 ohms wouldn't be 3. In addition power to each would not be balanced. Power will tend to go to path of least resistance (2 ohms speaker). I never liked mixing in parallel. My thoughts...
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
post #6 of 10 (permalink) Old 04-03-2014, 11:57 AM
Absolutely correct. For those who aren't familiar with electronics, the resistance in a parallel circuit is always lower than the lowest resistor, so that means since 2 ohms is the lowest, the resistance is going to be lower for the parallel circuit.
Sent from my SPH-L710
post #7 of 10 (permalink) Old 04-03-2014, 01:29 PM
Eshaw301's Avatar
I stand corrected. Did my math and forgot about the path of least resistance and using the lowest ohm as the baseline. My bad...I hope I didnt cause him to burn up his amp!!!
Eshaw301 is offline
post #8 of 10 (permalink) Old 04-05-2014, 11:44 AM
What 5.25 to 6.5 inch adapter are you guys using for the Kappa 62.11i speakers? Thanks!
Boomertx is offline
post #9 of 10 (permalink) Old 04-05-2014, 11:49 AM
Q-Hog's Avatar
Hawg Wired.
Q-Hog is offline
post #10 of 10 (permalink) Old 04-05-2014, 12:03 PM
Thanks!
Boomertx is offline
pioneer speaker install inner fairing faceracer Do-IT-Yourself 67 12-13-2018 08:06 AM
Inner Fairing speaker Wiring TYM2GLIDE Audio 0 07-10-2013 12:29 PM
Fork Cover hitting inner fairing RF speaker adam_twenty6 Audio 9 04-03-2013 06:51 AM
Painted inner fairing and speaker bag lids on the way. BigDeez Paint & Bodywork Section 6 07-01-2012 11:53 PM
Inner fairing speaker w/o cutting g;ove boxes peener Audio 6 02-16-2011 05:31 PM
