Ultra rear speaker pins - Road Glide Forums
post #1 of 6 (permalink) Old 03-30-2014, 07:53 PM Thread Starter
Does anyone know which pins on the 35-pin connector are the factory rear speaker outputs on a FLTRU? I'm upgrading my audio and have the fronts pretty well wrapped up, just need to identify the rear outputs to run to the amp. Anyone got that info?
Thanks,
G
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Those white lines are just Road Chum ... and my Shark is HUNGRY!
2012FLTRU_BigBlue is offline
post #2 of 6 (permalink) Old 03-30-2014, 08:05 PM
ERod62's Avatar
Sent from Motorcycle.com App
ERod62 is offline
post #3 of 6 (permalink) Old 03-30-2014, 08:32 PM Thread Starter
Originally Posted by ERod62 View Post
Thanks ERod. These don't go to a connector before running to the rear speakers, do they?
Cheers,
G
post #4 of 6 (permalink) Old 03-30-2014, 09:36 PM
ERod62's Avatar
Here is from the 35 pin to speakers layout and connections
ERod62 is offline
post #5 of 6 (permalink) Old 03-30-2014, 09:41 PM
ERod62's Avatar
ImageUploadedByMotorcycle1396233619.538222.jpgImageUploadedByMotorcycle1396233647.619986.jpg
Close up shots
ERod62 is offline
post #6 of 6 (permalink) Old 03-31-2014, 05:32 AM Thread Starter
Thanks again Erod. Looks like I need to make another wire/pin set to run from the 35-pin connector to the amp. If I leave the original pin set intact, I can run mating pin from the amp back to the harness. Just need to sort out part numbers for the pins. I'll start digging the forum and see if anyone has that info.
Thanks again!
Cheers,
G
pins inside the weather pack connectors Bubba Controls & Handlebars 8 02-16-2012 08:30 PM
Need clarification on HK rear speaker pins SickRick Audio 6 01-15-2012 05:32 PM
HOG Pins/Patches (1998-2007) dspencer Miscellaneous for Sale 0 12-08-2011 05:08 PM
Lever pivot pins fugly1 *General Road Glide Discussions/Pictures 0 11-03-2011 08:28 PM
Shark week pins for sale (limited number) HUTMO ARCHIVES-SWI Gettysburg, PA 13 09-09-2011 09:29 PM
