Blowing in line fuse Hawg Wire Amp ?? - Road Glide Forums
post #1 of 4 (permalink) Old 04-01-2014, 06:57 PM Thread Starter
redbaron's Avatar
Just installed my CS300 Hawg Wire Amp, installation went fine until I got to the tuning part. started with gain at zero (volume at 75% per instruction) and slowly increased gain...not even half way up and amp went lost power. pulled in line fuse out - looked ok. put fuse back in and power came back on. started the process from beginning and there it happened again. not sure what's going on ( I am not an expert at this) bad ground or connection?? any suggestion would be appreciated.
2012 Vivid Black, FM Ceramic 2-1-2 Header + 4" slash up mufflers Power Vision, PM Super Gas MERC A/C, 12" Windvest, CVO Solo Seat, XT Rokker & Hawgwire cs300 Amp, 10" Outlawz, CD Led's, Arlen Ness lowers, Ohlins S36E + progressive monotubes
redbaron is offline
post #2 of 4 (permalink) Old 04-04-2014, 04:11 PM
shrap's Avatar
I think your amp clipped during setup and when you took out the fuse and put it back you cut the power source and allowed it to reset and to power up again. The amp has a protection circuit that shuts it off if overdriven too long.
shrap is offline
post #3 of 4 (permalink) Old 04-04-2014, 04:16 PM
shrap's Avatar
Try running the radio at 75% power output using a good digital source (cd, mp3 with high mb count) to setup. The instructions that came with the amp are really detailed.
Makes sure you are in phase, meaning all speakers are pushing at the same time.
Make sure your power source is solid and that you are well grounded.
shrap is offline
post #4 of 4 (permalink) Old 04-06-2014, 11:18 AM Thread Starter
redbaron's Avatar
Thanks shrap, you were correct. I had undercurrent due to bad crimp on power cable and I also relocated the ground (not a blown fuse). That did the trick...working great now
redbaron is offline
blowing fuse amp .ShortBus. Troubleshooting for Road Glides 12 07-05-2015 02:59 PM
Lost All Sound, Blowing Amp Fuse The Volusianator Audio 24 06-29-2015 07:08 PM
Lights Fuse Blowing!!!! 09Sharknose Lighting 9 04-30-2014 06:12 PM
Blowing headlight fuse Countryboy Lighting 7 03-29-2014 05:04 AM
blowing ignition fuse drmudd Troubleshooting for Road Glides 4 07-31-2012 05:02 PM
