Upgrading system Concerns - Road Glide Forums
post #1 of 3 (permalink) Old 04-03-2014, 10:01 PM Thread Starter
sldmedic's Avatar
Am upgrading my system and am hoping this will work out. I have some parts in garage that I have come across from doing friend some favors. Question will combination be ok? Also what is the best Splash Guard for radio you all recommend? Thanks for all the help.
1. Kenwood Head unit- BT-848U
2. 4-Kicker Component Speaker (spoke w/ Kicker and they said they are water resistant)- KS602
•Component system with two woofers, two tweeters, and two crossover networks
•Symmetrical 12dB/octave high-pass-12dB/octave low-pass crossover/protection network with 3-position tweeter attenuation
•75 Watts RMS (150 Watts peak) power handling with 4-ohm impedance
•35 Hz-21kHz frequency response
3. Alpine PDX-5- 4 channel+Mono Amplifier
•4 ohms - 75 watts x 4 chan. + 300 watts x 1 channel
•2 ohms - 75 watts x 4 chan. + 300 watts x 1 channel
•Bridged, 4 ohms - 150 watts x 2 chan. + 300 watts x 1 channel
•DC-DC PWM (Pulse Width Modulated) power supply
•LED power and protection indicators
sldmedic is offline
post #2 of 3 (permalink) Old 04-03-2014, 10:10 PM
RedneckMedic66's Avatar
Sounds like everything should work just fine. Are you getting the retro radio kit or anything to use handle bar controls. As well as the adapter to mount the head unit
GLIDE OR DIE!!
RedneckMedic66 is offline
post #3 of 3 (permalink) Old 04-03-2014, 10:24 PM Thread Starter
sldmedic's Avatar
system upgrade
Got the Hawg Wire HUA360 kit to maintain the controls.
sldmedic is offline
Upgrading Charging system for audio upgrades??? 09Sharknose Audio 11 12-08-2014 01:53 AM
Engine Work Being Done Today, Pics and Concerns Nevadasun *General Road Glide Discussions/Pictures 11 01-11-2013 08:55 AM
Helmet concerns SharknoseScott Helmets 24 11-14-2012 02:36 PM
purchase concerns Eldorado Road Glide Specific Discussions 44 01-30-2012 06:50 PM
