stereo Problem - Road Glide Forums
post #1 of 4 (permalink) Old 04-08-2014, 06:30 PM Thread Starter
locokk64's Avatar
stereo Problem
I just finished installing my stereo system and when I turn the switch to the ignition position I get a hiss, high pitch noise, the stereo could be in any mode, cd,radio,pandora etc. Now when I turn the switch to accessories it doesn't make that noise. I am assuming to have a poor ground. but I have ran my ground wire from the amp to 3 different positions on the chasis and I still have the noise. does my alpine stereo has to be ground it also?? I am running the HUA 360 from Hawg wired and the RS400 from Hawg wired. I have wired the ground from the stereo to the HUA360 as per instructions.......any ideas??? Please help!!!!!
2011 road glide custom
d d fat cat boarzilla black exhaust
br handle bars
s e air breather
klock werks front fender
streched saddlebags
air brush flames
cvo rear fascia conversion
all around battistinis
progressive monotube 2" drop
black lower sliders
arlen ness cowbells
cool dash and fuel cap.
21" PM wheel
more coming..
locokk64 is offline
post #2 of 4 (permalink) Old 04-08-2014, 07:01 PM
I had the same thing happen, figured it probably had something to do with the EFI, I bought a cheap filter from e-bay, problem solved, I'll see if I can find the link, it's been over a year now.
post #3 of 4 (permalink) Old 04-08-2014, 08:22 PM Thread Starter
locokk64's Avatar
Please find that link for me bro. I will appreciated.
br handle bars
s e air breather
streched saddlebags
air brush flames
black lower sliders
arlen ness cowbells
21" PM wheel
more coming..
locokk64 is offline
post #4 of 4 (permalink) Old 04-10-2014, 12:55 PM
Where did you mount your amps ground wire at? I just finished my install last night and it did the same thing. I moved my ground from the chassis to the battery negati e and it sounds right now. Just a thought.
RoadGlideGooser06 is offline
Stereo Upgrades? zuppy51 Aftermarket Accessories 28 05-05-2016 12:23 PM
4 ohm spkrs 2ohm stock stereo , problem? 2008HDrdgldr Audio 1 05-02-2013 09:14 PM
Harley stereo problem hdtwincam Troubleshooting for Road Glides 4 02-25-2011 05:58 AM
stereo problem Gar Troubleshooting for Road Glides 8 09-01-2010 11:09 AM
Aftermarket Stereo Intaller San Antonio Area jbrawkus *General Road Glide Discussions/Pictures 0 03-02-2010 09:20 AM
