Amp gains and final adjustment advice needed - Road Glide Forums
post #1 of 6 (permalink) Old 04-08-2014, 07:16 PM Thread Starter
Talking Amp gains and final adjustment advice needed
Installing new system this weekend and looking for advice on tweeking adjustments.
The system consists of:
Sony MS60 Head
RF 300x4 Amp
Fosgate T165 speakers in stock locations and another set in the inner faring location (5" hole saw makes life easy & painted inner faring)
Dynamat on inner and outer fairing
Vtwin audio mount kit
What volume do I run the head unit at to adjust gains ?
Any advice would be helpful, I'd like put the outer back on and be done the first time.
Thanks All
vinman4444 is offline
post #2 of 6 (permalink) Old 04-08-2014, 07:32 PM
Most say set volume at 75%, then set gain accordingly. Thats how I set mine up, but I'm no expert.
The bad thing is, the sound wont be the same after you mount the outer fairing.
Big_gary is online now
post #3 of 6 (permalink) Old 04-09-2014, 04:56 AM
stripclub's Avatar
+1 ^^^^ also have bass and treble set flat during adjustment, then you can adjust to different music while listening.
stripclub is offline
post #4 of 6 (permalink) Old 04-09-2014, 07:11 PM Thread Starter
Did you have to add more gain after you heard how it sounded with the outer back in place ?
post #5 of 6 (permalink) Old 04-09-2014, 08:31 PM
I hung it on a couple of times when adjusting. I believe, I was turning the gain down, more to due with the speakers rather than the fairing tho.
post #6 of 6 (permalink) Old 04-29-2014, 06:13 AM
wanted to give this post a bump versus asking again in another post...
just installed a soundstream pn4.520 behind the stock Headunit...
I'm looking for the same info...and tips
I can reach my gain adjustments with the left headlight out so thats something to consider when mounting your amp...
It's a mighty world we live in!
but the truth is...
We're only passin through.
NK-Highway is offline
Adjusting Gains On 4 Speaker System- Front and Rear scottrgs Audio 2 06-12-2017 06:50 AM
Help needed - Speaker placement and gains Sincecrazy Audio 4 02-05-2017 10:16 AM
Dyno Day good gains! RKRGH *General Road Glide Discussions/Pictures 4 07-22-2013 06:10 AM
PBR300x4 Amp gains rdrnr03 Audio 3 04-22-2013 08:47 PM
Madstad final adjustment neversatisfied Windshields 43 11-30-2012 12:51 PM
