OEM Radio Diag Codes? - Road Glide Forums
post #1 of 5 (permalink) Old 04-11-2014, 09:43 PM Thread Starter
smhusker's Avatar
My OEM radio while riding just goes from being on FM to AUX for no apparent reason. I have had the fairing of and all of the connections are tight there were no lose or frayed wires. When I ran the Diagnostic the code came back; Dia B2008 FC1 Short to GND PN 23-22 (GY-GN). Has anybody this trouble with their OEM radio or where I can find out what the Diagnostic code means. Any help would be appreciated.
smhusker is offline
post #2 of 5 (permalink) Old 04-11-2014, 10:49 PM
Most people just get rid of them for aftermarket units which ill be doing soon too. The stock HK head units arent the best.
post #3 of 5 (permalink) Old 04-12-2014, 12:20 AM
hd4cruzin's Avatar
I would suggest calling Iron Cross and ask them what the codes mean. Great guys to deal with.
Sent from Motorcycle.com App
2012 FLTRX BBP
hd4cruzin is offline
post #4 of 5 (permalink) Old 04-12-2014, 08:42 AM
Howardsternspenis's Avatar
Hand controls?
Have you checked the hand controls to make sure theres nothing loose or something shorting out a connection.
In my old motorcycle I had a problem with the ignition switch, it turned out to be a teeny, tiny spiderweb in the contacts.
Good luck!
HSP
Howardsternspenis is offline
post #5 of 5 (permalink) Old 04-12-2014, 09:19 AM
Try googling Harmon Kardon radio diagnostics pdf. You will find the instructions for doing a diagnostic on your radio.
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 12:56 PM
How do I check diag codes with Thundermax installed? SIG556 ECM/Fuel Management systems 2 09-07-2012 08:23 PM
Old school diag... steering suspension I NEED HELP! justchillaxin1 Troubleshooting for Road Glides 0 08-22-2012 08:41 PM
Installing aftermarket amp to OEM radio Q's ddaarr Audio 9 03-16-2012 07:37 PM
