Burning smell, and amp shorting out. Any ideas why? - Road Glide Forums
post #1 of 7 (permalink) Old 04-11-2014, 09:51 PM Thread Starter
Bubba's Avatar
I've been using a Rockford PBR 300x2 and Polk mm651's for about two years now. Today I washed my bike and went for a ride. After a few minutes I started to smell a burning smell then my left speaker let out a little smoke. I pulled the fairing off and the speaker is fried. The weird thing is the other channel of the amp and other speaker is fine. And I tried the channel that messed up on an old speaker and it shoots sparks when it's connected or if I brush the wires together. Just can't figure out if it was just this amps time to go, or if I did something wrong? The only thing I can think go that I could of done wrong would be, I just did the Monroe shock project and had a ground problem so I had to unhook the positive side of the battery two or three times. Just really frustrated.
Bubba is offline
post #2 of 7 (permalink) Old 04-11-2014, 09:55 PM
You brushed the wires together for the output of the amp? If so, you might have fried it then.......
Sent from my SPH-L710
post #3 of 7 (permalink) Old 04-11-2014, 10:22 PM Thread Starter
Bubba's Avatar
No the output for the channel that had already fried. It was throwing sparks when I hooked it to the old speakers, so I was curious and figured it was already junk anyway.
Bubba is offline
post #4 of 7 (permalink) Old 04-11-2014, 10:41 PM
Two years. .... I guess that means warranty is gone. Replace it with a class D amp like the Sound Stream, you'll like it, also might want to try a set of Infinity Kappa since you're going to have to get speakers also...... system will cost less and I'm sure you'll be happy with it. That's just my opinion.
post #5 of 7 (permalink) Old 04-11-2014, 11:00 PM
glide1's Avatar
You said you washed the bike, Maybe some water got into the Fairing and shorted out the Amp??
glide1 is offline
post #6 of 7 (permalink) Old 04-12-2014, 12:20 AM
Gray Beard
lundboy1's Avatar
I've had amps and speakers give trouble free service for years and then traded up or sold the vehicle, I'd retrace my steps through you last mod. Just to be sure, but it's not likely with just one blown channel.
Sent from Motorcycle.com App
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #7 of 7 (permalink) Old 04-12-2014, 06:24 AM Thread Starter
Bubba's Avatar
I thought the same thing Glide1, but when I pulled it apart it was dry inside. I had also made my mind up on the infinity speakers, I was looking at the 6211.i , but honestly I was thinking of going back with the Rockford amp mine worked just fine for two years under pretty harsh conditions for an amp I figured, and it just now gave me the first problem.
Bubba is offline
Any ideas on get the most $ out of my total FLTRX vontoughguy *General Road Glide Discussions/Pictures 6 08-07-2017 05:14 PM
Smell oil burning help WOOSAB Fluids and Lubricants 4 07-08-2016 11:17 PM
STRONG gas smell. Any ideas?? RGCBandit Troubleshooting for Road Glides 33 01-04-2014 12:56 PM
How to get the smell out? Brando Clothing 23 03-16-2012 06:41 PM
Why? Why? Why? CMS *General Road Glide Discussions/Pictures 16 04-11-2011 01:46 PM
