Speaker Clipping - Road Glide Forums
post #1 of 9 (permalink) Old 04-15-2014, 05:03 PM Thread Starter
Speaker Clipping
New Install
Sony DSX-MS60
Rockford Fosgate PBR300x2
ZX654-100 6.50 4 OHM COMPONENT SPEAKERS
Amp gain set at 6
volts at 5
Hertz at 100
Speakers are cutting out when volume is turned up high at highway speeds.
I assume this is what is referred to as "clipping"
If I back the volume down it stops, but is not as loud as I thought it would be with the upgrade.
Any suggestions?
thank you
scorpiohd is offline
post #2 of 9 (permalink) Old 04-15-2014, 05:37 PM
Check the connections, and you may need to adjust the gain on the amp down a little.
Sent from my SPH-L710
post #3 of 9 (permalink) Old 04-15-2014, 05:41 PM
How did you hook up the amp ? Did you use the low level rca plugs or go with a high level hook up ?
Big_gary is online now
post #4 of 9 (permalink) Old 04-15-2014, 06:27 PM Thread Starter
I used the RCA plugs from the HU to the AMP input.
But I was reading the RF amp instructions again and it says "when the installation requires a High Level(speaker) input, the RCA harness needs to be cut on the wire side of the Y-splitter. discarding the RCA's and wiring the wires directly to the HU.
post #5 of 9 (permalink) Old 04-15-2014, 06:49 PM
The low level hook up is better if you have that option. I was not sure about your sony. If you hooked the amp up the high level way the the HU speaker wires dub as remote power (in)and the remote power (in) on the the amp turns into a remote( out) for adding additional equipment.
Sinse you use low level input , this isn't your problem.
I got my amp's gain set between 4 & 5 and can turn the volume all the way up , adjusting base only . I'm still running the HK HU and the older Hogtune 5x7 speakers.
post #6 of 9 (permalink) Old 04-15-2014, 07:27 PM
If you are using an aftermarket head unit def use the RCA cables. Not sure if the Rockford amp has a switch like the Arc Audio amp to select hi or low input. Make sure it is on low if it does have one and you are using the RCA's. Next you will probably want to turn the crossover frequency up a little bit. 100 hz is a little low. At low to mid volume it will be fine but once your moving down the road you will want more vocals and highs and the 100 hz setting will let those play into distortion and cause the clipping you are getting. set your setting on the head unit to flat first and then gain the amp. Turn the volume up then turn the gain til the speakers are about maxed out then back the gain down a little. After that you can kind of fine tune the sound with the setting on the radio after that. Hope it helps.
V&H Exhaust//Stage 1 intake//6k HIDS//12" KW Flare//12" Buky Assaults// Arc Audio 125.2// Alpine 5 1/4 components// Alpine head unit//color matched gauges//chrome this chrome that
FLTRick is offline
post #7 of 9 (permalink) Old 04-15-2014, 07:54 PM Thread Starter
The RF amp has a switch that can be set to High Pass, All Pass or Low Pass. Mine is set to HP. There is also a frequency dial that can be set from 50-500hz. I believe the last time I set it, it was at about 100hz (been tweaking this thing for several weeks). The HW speaker instructions give a "typical amp settings" set up of 75-200hz, HP, and gain 1/2-3/4 up.
I had a friend of mine, who used to own a car stereo shop, adjust the HU last week and he fine tuned the HU and got it go to a much higher volume without clipping. But the fairing was on, so he couldn't make any amp adjustments. It's close just not where I think it should be.
post #8 of 9 (permalink) Old 04-15-2014, 08:53 PM
hd4cruzin's Avatar
I don't have the RF amp, But when I had Iron Cross put front pre outs on my HK last month, they asked what amp I was using.
They said if you are using the RF amp to go with High level inputs, not the RCA connection. I have heard others say this as well. For some reason the RF does;t like the RCA connections.
Good Luck.
2012 FLTRX BBP
hd4cruzin is offline
post #9 of 9 (permalink) Old 04-21-2014, 04:52 PM
everyone keeps saying the PBR doesn't do well with the RCA inputs. I just done have this problem. My alpine has 4 volt pre amps, many top end head units have 5 volt preamps. My buddies Kenwood has over 5 volt preamps.
I have notices lots of Sonys only have 2 volt preamps. Could this be why the PBR doesn't do so good. Lots of head units out there only have 2 volt preamps.
2013 FLTRX Road Glide Custom, V&H Pro Pipe, Fuel Moto air cleaner, Woods TW-222 cams, Woods Alpha series lifters, Power Vision w/ autotune pro. HD king color match tour pack.
Liquidr1 is offline
Lower Fairing Speaker pods: How did you guys run the speaker wire? Slider57 Audio 3 02-10-2018 03:12 PM
Speaker lid speaker help Heavy Metal Audio 7 10-27-2017 03:07 AM
HK clipping above half volume? Liquidr1 Audio 24 02-25-2014 08:08 PM
6"x9" speaker kit that fits HD speaker lids JuicedHD Audio 1 01-18-2013 06:19 PM
Is my RF PBR 300 amp " clipping"????? HDFFR Audio 13 12-04-2012 12:46 AM
