Odd Problem - Road Glide Forums
post #1 of 12 (permalink) Old 04-18-2014, 12:21 PM Thread Starter
AtomiCapricorn's Avatar
Odd Problem
I installed the HD iPod interface with saddlebag tether, and it works great except for the occasional clipping in the right fairing speaker. (For what it's worth, I also installed the upgraded Boom! fairing speakers.) This does not happen at all when I use the CD player, or when I listen to the radio.
I do notice that the speaker clips when I open and close the saddlebag. I've wiggled the connection, and some minor clipping does occur. I'm using an iPhone 5 as an iPod at the moment, so I have to use a docking connector-to-lightning adapter.
Theories? Suggestions (other than "get an Iron Aces unit!")?
'13 FLTRX, BBP, Vivid Black painted inner fairing, 9" Windsplitter, 14" W1 Chubbys, Get-A-Grips, Daymakers, ABS, Cruise, Security, 4 Speaker HW/Jensen HD1BT System, Fuel Moto Jackpot Header/Nightstick Exhaust, Powervision, Fueling 543 cams (95HP/104TQ). Yay, me!!
AtomiCapricorn is offline
post #2 of 12 (permalink) Old 04-18-2014, 12:35 PM
PGR
PGR's Avatar
Find someone with an older iPod to try. It sounds like it's the docking adapter.
Ron..........................
PGR is offline
post #3 of 12 (permalink) Old 04-18-2014, 12:52 PM
Jay2Beers's Avatar
The only thing I can think of is - change wires - but get other opinions for sure,... Some good sound shops will help out sometimes (good pr for them).
'13 Blk RGC crs/abs/sec 103 Stg2 255cam-plus D&D Boss Fatcat SE Super Tuner. Klockwerks 12", Blk 10"Chubby w/Blk Get-A-Grips. Skunked Day Maker. CD GEN2001157Amber/Wht Front & Red Rear Smoke Lens w/Magic Strobe & bits more, Always a WIP
Jay2Beers is offline
post #4 of 12 (permalink) Old 04-18-2014, 12:53 PM
Jay2Beers's Avatar
Originally Posted by PGR View Post
Find someone with an older iPod to try. It sounds like it's the adapter.
+1 on this too,... Least expensive path always first.
post #5 of 12 (permalink) Old 04-18-2014, 08:01 PM Thread Starter
Thanks guys!! I kind of figured the adapter would be an issue. It's kind of weird that the MoCo doesn't offer a Lightning cable for this application. I'm looking for a 4th generation iPod to leave semi-permanently in my saddlebags.
post #6 of 12 (permalink) Old 04-19-2014, 09:17 AM
thedude's Avatar
I am using a touch and had the same problem. Unplugged it and plugged it back in and so far so good. The cables on these things seem kind of crappy.
thedude is offline
post #7 of 12 (permalink) Old 04-19-2014, 10:02 AM Thread Starter
Are you using an adapter?
post #8 of 12 (permalink) Old 04-19-2014, 10:15 AM
mmfinn's Avatar
I'm using an adapter too. What I found is that you have to make sure the plug is in firmly. Couple times I thought it was plugged in securely and had the same issue. Pushed it in with a little more pressure and no issue.
mmfinn is offline
post #9 of 12 (permalink) Old 04-19-2014, 05:26 PM
I've used the docking to lightning in my cage - had similar issues. You could make a velcro strap that starts around the wires that you can loop up around your phone when you put it in there to keep it tight.
jrich4411 is offline
post #10 of 12 (permalink) Old 04-19-2014, 07:16 PM
thedude's Avatar
No adapter. Thought I had it plugged in tight but I guess I didn't. Guess I have to double check from now on.
thedude is offline
New folks with ODD problems - sometimes real odd 4getNo1 General Off-Topic Discussions 62 03-04-2013 06:23 PM
HELP! New and odd motor noise! bad86ta *General Road Glide Discussions/Pictures 1 05-30-2012 07:42 PM
Odd they can't make Sedona Orange anymore.... Quicksand Road Glide Specific Discussions 16 08-02-2011 01:46 PM
Post YOUR Funny/Odd Signs you see out there! DreamRider *General Road Glide Discussions/Pictures 65 05-16-2011 01:18 PM
Odd grip question. cem1133 Aftermarket Accessories 9 06-04-2010 07:18 PM
