Hi-level input wireing (PN4.520d) - Road Glide Forums
post #1 of 22 (permalink) Old 04-19-2014, 06:55 AM Thread Starter
after reading several posts I have decided to move away from the plug and play kits like some of the Hog tunes or one's that HillCounty offers...
I see that the soundstream pn4520 amp is continually mentioned here and I have researched it on the soundstream site...
My plan right now is to go with
Soundstream PN4.520
JM ROKKER 7.25 with the tweet and mid grill (open to other suggestions)
I have yet to ever pull the fairing apart but I assume that the HK head unit does NOT have RCA outs?
therfore you would use the speaker out leads from the HK to the Hi level inputs on the sound stream amp?
do you cut or just remove the wiring from the speakers to go to the Hi lev inputs or is there an adapter that I have not seen yet...
It looks like the hi level inputs on the soundstream has two 5pin adapters LF/R/F L/R R/R and center ground etc...
Does the amp come with those pigtails I didnt see it listed or shown?
I plan on running the pn4.520 bridged two channel for now... I dont see adding lid speakers but you never know, so the four channel amp would be nice if I ever did
I'm pretty good at wireing and fabricating so I dont plan on buying a ready made mounts or anything else that I cant make myself but is there anything else that I should be purchasing for this basic system?
thanks in advace for any advice or hints from those of you that have used this
It's a mighty world we live in!
but the truth is...
We're only passin through.
NK-Highway is offline
post #2 of 22 (permalink) Old 04-19-2014, 09:20 AM
Yes , you will cut the HK's speaker wires( out) and run them into the amps high level input.
I dont own the Sound stream , but I have never bought a new amp that didn't come with all the pigtails needed for hook up.
Take your time and solder and heat shrink all wire connections and you'll be fine.
post #3 of 22 (permalink) Old 04-19-2014, 10:33 AM
mtloafer's Avatar
Soundstream PN4.520
I just installed a pn4.520, and yes it comes with the wires to wire the high level inputs.
I would caution you that this amp is large, so when fabricating a bracket you dont have a lot of extra room.
I had to revise my bracket twice before my outer fairing finally cleared it.
In the end , I love the sound difference! It was definitely worth it!
06 Road Glide FLTRI
I Always Gotta Be F*%$ing with Something!
mtloafer is offline
post #4 of 22 (permalink) Old 04-19-2014, 11:25 AM
Fenny's Avatar
I just installed the same amp. As was mentioned, it does come with the pigtails. I would make sure you have all wiring & connections either purchased or available at a store nearby. I used 8ga wire from the amp to the battery power & ground, and was unable to find the proper supplies at any nearby stores. I ended up buying most everything from amazon and had to wait for the mail.
I purchased my speaker & power / primary wire from a company called Knu Koncepts through Amazon... Seems to be some good quality stuff:
I also bought my fuse holder & fuses from Amazon:
I should have bought ring terminals for the 8ga wire online too but managed to find something that did the trick at the local hardware store.
Just make sure you have all the supplies you need for wiring before you start. It will make things less stressful. Everything will plug into the amp - pigtails for the hi level input, and insert , set screw type connections for the power, ground, remote in/out, & speaker out. Not sure what kind of connections at the speakers you mentioned though.
Oh, I also skipped an amp mount entirely & just used adhesive velcro to stick the amp between the glove box & inner fairing - its a tight fit, but it works.
mzierk likes this.
2004 FLTRI - Custom Paint: Glacier White Pearl & Vivid Black with Blue Flake, 12" Buky Malos, Dragos Dragula, Monroe DIY Air Shocks
2001 XLH1200 - Black & Chrome
Fenny is offline
post #5 of 22 (permalink) Old 04-19-2014, 04:43 PM Thread Starter
thank you for the replys and information...
Fenny, does that mean the amp is out in the open and visible?
I like the idea of that for servicabilty but how does it look... and is that amp as it is a MC amp weatherproof?
but the truth is...
post #6 of 22 (permalink) Old 04-19-2014, 04:52 PM
598Malibu's Avatar
Another option is to send your HK head unit to Iron cross audio and have pre amp outputs installed.
Sent from Motorcycle.com App
2012 Big Blue Pearl FLTRU
72 Chevelle with Procharged 598
598Malibu is offline
post #7 of 22 (permalink) Old 04-19-2014, 06:08 PM
Fenny's Avatar
The amp is still inside the fairing, I should have elaborated a bit.
There is a sort of pocket on the inside of the inner fairing on both sides - between the glove box space and the inner fairing wall. Unfortunaley, I did not take any pics, but I found this thread with a pic of what looks to be the Soundstream 2ch amp in the same location - post #7...
https://www.roadglide.org/showthread.php?t=126049
I do not know how water or weather resistant the amp is but the servicability of an exposed amp would be great. I do believe that if I pop the headlights out I may be able reach the gain controls with a screwdriver. Though I haven't actually tried it.
Fenny is offline
post #8 of 22 (permalink) Old 04-19-2014, 06:42 PM Thread Starter
Good info!
thanks Fenny
I will look into that mounting option...
Malibu...I did not know about that company another good idea,
thanks
but the truth is...
post #9 of 22 (permalink) Old 04-25-2014, 04:12 PM Thread Starter
Attachment 114874Attachment 114882
7.25" JM rockkers came in today still waiting on the amp but I couldn't wait so I'm running them on the stock HK head....WOW these speakers thump even with no amp I think some people would be quite happy with out an amp but I need More Power!!!!
but the truth is...
post #10 of 22 (permalink) Old 04-25-2014, 04:14 PM Thread Starter
I was trying to upload multiple pics of the install but for some reason only one came up so this is kind of a test post as well
but the truth is...
SoundStream PN4.520D - Ghost Radio Station GRider Audio 9 03-25-2016 05:16 PM
Ss pn4.520d VS ss st4.1000d sjohn1024 Audio 9 02-27-2016 09:35 PM
Biketronics 7.1 and 6.5's with SS pn4.520d amp Gixxere Audio 6 10-11-2015 10:51 AM
AMP mounts for Soundstream PN4.520d Jims79FLH Parts for Sale 3 10-01-2014 03:46 PM
Got my PN4.520D...Now a couple questions. Fenny Audio 9 04-21-2014 08:47 PM
