amp install quick question - Road Glide Forums
post #1 of 2 (permalink) Old 04-20-2014, 08:56 PM Thread Starter
motosig102's Avatar
Im thinking about using the alpine headunit powerpak. It is a 4 channel 2ohm stable amp. What Im wondering is for right now I am only going to be running the 2 speakers in the fairing. Can I only run the first two speakers leads(front) and not the other two(rear)? Once again the component system I am running is 2ohms. Another question is I currently have a kicker dx125.2 although this amp is not hooked up nor does it have high level inputs. So I will need a line out converter correct. Also this amp is 8.3125x8.375 is this going to be too big to mount inside the fairing?
motosig102 is offline
post #2 of 2 (permalink) Old 04-21-2014, 08:07 AM
hometoast's Avatar
the answer to your first question: yes, you can run only two channels and not use the other two. It's been asked and answered before a couple times.
more than 8x8"... how deep is it? I'm going to GUESS no... it'd be a tight fit. I replied mostly to subscribe to see if someone made one like that fit
Are you set on keeping the stock head unit? The cost of a new Alpine is less than sending the unit to get pre-outs installed in it. I don't know what a line-out converter would cost otherwise, but you can sell your stock unit ~$350 on ebay (more if you want to wait longer than I did), $100 more than the new unit.. leaving that for the purchase of the install kit.
2013 Candy Orange FLTRX
hometoast is offline
Quick install adjustable pushrods? Papi63 Engine Related 12 01-22-2014 06:54 PM
A few quick shock install questions Garemlin Suspensions 8 03-22-2013 02:19 PM
Quick amp question - 2 vs 4 channel Garemlin Audio 9 03-01-2013 07:43 AM
Grounding amp to frame - quick question JED50 J&M 2 03-01-2012 08:36 AM
Quick question about the wind deflector Big John Road Glide Specific Discussions 16 08-15-2011 09:01 AM
