Any tried the Infinity 63.9i - Road Glide Forums
post #1 of 6 (permalink) Old 04-20-2014, 10:42 PM Thread Starter
Bubba's Avatar
After toasting my first setup of the pbr 300.2 and Polk mm651's, I think I'm going a whole new direction with the next selection. I've read a lot of good things about the soundstream 4.520, and I think I'm set on that for an amp. Where I'm getting a little indecisive is on the speaker side. Leaning towards the four speaker( 2 inside the inner fairing and two in factory holes). I know a lot of you are running the infinity 62.11, which is what I'm probably gonna run in the factory spots. I'm wondering if anyone is running the 63.9 by infinity, was thinking of putting a pair of those on the inside part of the inner fairing with the thought that I could direct the sound a little better. Anyone have any experience with these or any advice to offer?
Bubba is offline
post #2 of 6 (permalink) Old 04-21-2014, 05:23 AM
OneSlickGlide's Avatar
I've not had any but I have been researching this to the hilt and I do t think you'll be able to mount that PN4.520D if you have inner speakers.
The people that I've seen use this amp had to mount it between the inner fairing and the glovebox due to the shear size. It doesn't fit above the radio either.
Dbell will be the man to talk to about infinity speakers also. Good luck.
OneSlickGlide is offline
post #3 of 6 (permalink) Old 04-21-2014, 06:11 AM Thread Starter
Bubba's Avatar
Didn't think that the extra 1 1/4" in length would keep it from mounting it where my fosgate currently is. I made a bracket that mounts it beside the radio from about the gauges down. I guess if that wouldn't fly I could step down to the 4.320 by soundstream or go with the nvx mvpa4 which is a touch smaller than the fosgate. Thanks for bringing that to my attention.
Bubba is offline
post #4 of 6 (permalink) Old 04-23-2014, 08:20 PM
zombie's Avatar
I was able to fit it in with 2 factory and 2 on inner fairing, I ran the pn4 520 along the side going top to bottom.
2009 FLTR, in the works, FM 107, 777cams, Jackpot Header, Power Vision,K&N high flow, 1" drop back, 12" windvest, K&N slip ons, 14" black apes, tri light , vented lowers ,misc..
zombie is offline
post #5 of 6 (permalink) Old 04-23-2014, 09:59 PM Thread Starter
Bubba's Avatar
That's helpful info Zombie, do you happen to have any pics?
Bubba is offline
post #6 of 6 (permalink) Old 04-27-2014, 10:55 PM
zombie's Avatar
Sorry, no pics all buttoned up,
I put amp on CIG lighter side, made to remove air temp gauge and put fuel gage in top guard area and omit the air temp, the amp does fit.
zombie is offline
Robin Williams dead at 63 Bruckus General Off-Topic Discussions 13 08-12-2014 10:19 AM
31-2500 on Amazon 236.63 93-331-29psi Suspensions 11 08-02-2014 10:19 PM
Infinity Kappa 62.9I speakers question killintime Audio 4 05-10-2014 12:08 AM
Infinity Kappa Speaker Road Test Q-Hog Audio 4 08-09-2013 01:47 PM
To Infinity, and Behind!!! OldNerdGuy General Off-Topic Discussions 22 11-22-2011 08:45 PM
