Looking for a wiring diagram or any info... - Road Glide Forums
post #1 of 1 (permalink) Old 04-22-2014, 09:16 PM Thread Starter
yzergod's Avatar
Question Looking for a wiring diagram or any info...
2001 Screamin' Eagle Road Glide tour pak. Has the quick disconnect kit. I removed the cinder-block (non-working) 10 disc cd changer and tossed it a year ago. The only part of the tour pak that needs juice is the led light bar on the spoiler. But, I would like to know what the other wires do and connect to. I have 2 shop manuals for the Road Glide and neither have the wiring diagram for the Screamin' Eagle (CVO) upgraded sound system. Any ideas? The cd changer had a separate box that was some sort of controller or something. So, I have a plug that went to the changer that had power, disc select, next track, last track, etc. and a four prong that went to the other box. Worse case, I just leave it unplugged under the seat. But, I'd like to be able to use it in some custom capacity. At least remote (switched) power for another amp.
Thanks for any help...
2001 SERG
yzergod is offline
Rear light pinout/ wiring diagram japsw20 Lighting 2 08-26-2015 10:21 PM
Wiring diagram for control harness Murlsquirl Controls & Handlebars 8 10-05-2012 12:54 PM
fairing wiring diagram? pics? coryo Tech Area 3 04-25-2012 03:34 PM
Turnsignal bar wiring diagram bvette94 Lighting 0 07-24-2011 11:41 AM
Headlight wiring diagram Qman Lighting 2 07-06-2011 08:12 PM
