Rear speaker Placement - Road Glide Forums
post #1 of 3 (permalink) Old 04-25-2014, 08:52 AM Thread Starter
Hello everyone . After a rough year I'm crawling back in the saddle to finish my bike . I had a question about putting speakers in the saddlebags . My question is what's the best way to mount the 6x9's in the bags . Let me rephrase that .... should I bolt them right to the inside of the bag or build up something in between the bag and speaker . Thanks in advance
1rstfltr99 is offline
post #2 of 3 (permalink) Old 04-25-2014, 09:27 AM
Q-Hog's Avatar
They can be bolted right on if you an on installing one 6x9 in each bag. Mount it as vertical as you can to save space in your bag. You can drill nickel size hole in the same pattern as your speaker. Hope that help.
Q-Hog is offline
post #3 of 3 (permalink) Old 04-28-2014, 10:03 AM
UltraNutZ's Avatar
a typical 6x9 will fit perfectly towards the rear of the saddlebag facing inwards if that's what you're referring to. As for spacing them out, that all depends on the speaker you're using as some, the rubber surround protrudes out past the frame and moreso when the speaker is in motion.
As for drilling nickel sized holes in your bags.. I would not do that personally. That big of holes (.8") only serves 2 purposes, weaken the structure of your bag, and allow water in. Drill a bunch of smaller holes, 1/4" is plenty large enough.
2012 FLHTK - VTPBB
UltraNutZ is offline
Help needed - Speaker placement and gains Sincecrazy Audio 4 02-05-2017 10:16 AM
NY State Inspection Sticker placement? andytheuke Equipment-RG 17 03-29-2012 10:23 AM
Spot light placement Jeffdag *General Road Glide Discussions/Pictures 32 02-22-2012 10:31 AM
leather tool bag placement Unforgiven *General Road Glide Discussions/Pictures 7 06-11-2011 02:14 PM
Question regarding PCV placement Rsmith Road Glide Specific Discussions 1 04-03-2011 09:38 PM
