PBR300X2 Gain/Freq Settings - Road Glide Forums
post #1 of 6 (permalink) Old 05-13-2014, 08:45 PM Thread Starter
five2five's Avatar
Just picked up a Rockford Fosgate PBR330X2 and a pair of J&M Rockers for my '13 Road Glide Custom - my question is what are the optimum settings for the Gain and Frequency crossover on the amp?
five2five is offline
post #2 of 6 (permalink) Old 05-14-2014, 01:18 AM
Banned
Around 5 but if your good at listening, turn the auto volume control off, bass and treble to 3 or 4. Wherever u prefer. Then turn volume up until the bar is below the letter E in volume. Then start turning the gain up until it distorts then back it off a tad. Usually will be around 5
Sent from Motorcycle.com App
Scootin is offline
post #3 of 6 (permalink) Old 05-14-2014, 02:45 PM
yzergod's Avatar
1) On the stock H/K- Harley head units set your bass and treble to flat settings. Flat is the middle smaller bar on the display
2) Use a favorite CD or song off your iPOD (make sure EQ settings on iPod are off as well).
3) Turn your gain control on the amp all the way down. This is usually the counterclockwise direction.
4) With CD/iPOD playing, turn head unit volume up until you hear distortion then turn it back down a little until distortion is no longer present. If you can turn your head unit's volume all the way up without distortion then back it down to 75% and proceed.
5) Turn your gain up until your hear distortion, then back the gain control down until the distortion is gone.
Easy peasy!
2001 SERG
yzergod is offline
post #4 of 6 (permalink) Old 05-14-2014, 06:04 PM
zombie's Avatar
Good replies, On my sound stream they have High Pass / Fixed /Low Pass
I was told that HP is the safest not full range of freq.
Fixed is Full range of Freq
LP is for subs
What range have you guys run
My top speakers are 2 ohm J&M 7.25" thinking of HP to be safe
inner are RF P165 thinking of Fixed for full range of sound.
Any opinions?
2009 FLTR, in the works, FM 107, 777cams, Jackpot Header, Power Vision,K&N high flow, 1" drop back, 12" windvest, K&N slip ons, 14" black apes, tri light , vented lowers ,misc..
zombie is offline
post #5 of 6 (permalink) Old 05-14-2014, 11:24 PM
yzergod's Avatar
The best sound would be to leave the crossover at Fixed. I'd run the amp on Fixed and use the head unit to set the bass cutoff at 50hz. You can also do that setting in high pass on the amp, try it and see if it sounds passable. Especially if you're getting any distortion at volume or are worried about blowing your speakers. Using Fixed though I'd also watch your bass setting and volume at speed! HTH.
2001 SERG
yzergod is offline
post #6 of 6 (permalink) Old 05-15-2014, 06:50 AM
hometoast's Avatar
Also -- if you have the JM Rokkers, they have a built-in cross over and HPF. Someone tell me if I'm wrong, cuz if so, I got some adjustment to do
2013 Candy Orange FLTRX
hometoast is offline
Freq setting on diamond amp BigBubba Audio 1 12-31-2016 05:44 AM
Installing PBR300x2 Settings mrmoto95 Audio 1 02-19-2014 11:38 AM
New 500W Amp Gain Adjustment gpdstaffcapt J&M 2 02-15-2013 08:01 PM
anyone notice the weight gain of the 2013's? jeffb928 *General Road Glide Discussions/Pictures 8 09-07-2012 04:22 PM
