J&M Amp Ground Wire Help - Road Glide Forums
post #1 of 7 (permalink) Old 05-29-2014, 12:35 PM Thread Starter
tsmartt's Avatar
I am installing a J&M 250W amp on my 13 RGC. Instructions say to ground the amp with the negative ground from the battery on the frame. Can't figure out how to do that without removing the starter. Any other locations that the ground can be run on the frame? Or is there an easier way to get to the negative ground on the bike? All help is greatly appreciated.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #2 of 7 (permalink) Old 05-29-2014, 12:46 PM
hometoast's Avatar
I grounded my amp with a ring terminal on the bolt that holds the inner faring to the frame.
2013 Candy Orange FLTRX
hometoast is offline
post #3 of 7 (permalink) Old 05-29-2014, 12:48 PM
PGR
PGR's Avatar
After first disconnecting the negative battery cable from
the battery, connect the positive (red) lead from the amplifier
power harness directly to the positive post of the battery. Then
connect the negative (black) lead from the power harness to
the same bolt/stud on the frame that the negative battery cable
is connected to
. Then reconnect the negative battery cable to
the battery. (Figure A) Do not connect the negative (black) lead
from the amplifer to the negative post of the battery.
So in short.... follow the cable from the battery ground to where it bolts to the frame and attach the wire there.
Ron..........................
PGR is offline
post #4 of 7 (permalink) Old 05-29-2014, 12:54 PM Thread Starter
tsmartt's Avatar
PGR, I have the instructions. Problem is trying to get to the other end of the ground wire. It is on the bottom of the frame / top of tranny under the starter on my 13 RGC. Would love to attach it there but don't want to remove the starter to wire an amp. Any alternate location suggestions?
tsmartt is offline
post #5 of 7 (permalink) Old 05-29-2014, 12:58 PM
PGR
PGR's Avatar
I would think that any frame bolt that's not structural would work. Give J&M a call. They have always been helpful when I have called.
PGR is offline
post #6 of 7 (permalink) Old 05-29-2014, 01:16 PM Thread Starter
tsmartt's Avatar
Problem solved. Took battery out and found ground at frame from negative terminal. Thanks for the suggestions. I'm still waiting on a call back from J&M. That is why I posted. Trying to get this thing buttoned up today! Love the forum and all the help and support.
tsmartt is offline
post #7 of 7 (permalink) Old 05-29-2014, 01:32 PM
hometoast's Avatar
Awesome. Get that thing cranked up to 11!
AMP Install Power & Ground Wire Routing wevsspot Audio 4 05-08-2015 09:27 AM
Help with main ground wire. cruznmarine Audio 15 02-11-2014 01:12 AM
Amp wire and ground point Venomized Audio 6 01-09-2014 11:07 PM
Removing Ground Wire from turn Signal Housing.. gpdstaffcapt *General Road Glide Discussions/Pictures 0 03-27-2013 10:56 AM
Ground wire? Willy_B Audio 2 05-16-2012 11:08 PM
