Radio backlight not working - Road Glide Forums
post #1 of 10 (permalink) Old 06-01-2014, 08:00 AM Thread Starter
I just noticed the backlight on the radio not working last night. I really don't ride that much at night so I'm not sure how long its been this way. Is there a possible loose connection or something I can do? I am planning a trip next week and I really don't want to take it into the dealer right now. Who knows when I'll get it back.
Thanks
2013 BBP RGC
NorbJ is offline
post #2 of 10 (permalink) Old 06-01-2014, 08:58 AM
sportyguy69's Avatar
Prob just a bad connection. Take your finger and push on the display window and see if it comes on. The display on my 07 goes out every now and then I just push on the display and it comes back on. Check out this write up also.
http://www.v-twinforum.com/forums/el...ay-repair.html
If your going to do something give it all you got, might be the last time you ever do it !!!
sportyguy69 is offline
post #3 of 10 (permalink) Old 06-01-2014, 09:38 AM Thread Starter
Smile
Thanks for the info.
2013 BBP RGC
NorbJ is offline
post #4 of 10 (permalink) Old 06-01-2014, 09:52 AM
Mine goes out too. The radio still works just no display. I'm waiting for it to completely stop working then I will go with a nice aftermarket unit.
rlaf75 is online now
post #5 of 10 (permalink) Old 06-01-2014, 10:01 AM
Did you go to the display function on the radio and adjust the backlight. The backlight may be adjusted to where it is off.
post #6 of 10 (permalink) Old 06-01-2014, 10:35 AM
I had the same problem till I did this repair. No more problems.
post #7 of 10 (permalink) Old 06-01-2014, 03:17 PM Thread Starter
Interesting. I know you can adjust the display. But that only adjusted the darkness of the display it has nothing to do with the backlight. I have looked at the manual not unless I am missing something. Please correct me if I'm wrong.
Always willing to learn. The backlight is the orange/red background.
2013 BBP RGC
NorbJ is offline
post #8 of 10 (permalink) Old 06-01-2014, 05:15 PM
Gray Beard
lundboy1's Avatar
You lost an led on the circuit board
This is what they look like in the hk deck pushing on the face will only damage the LCD face , these leds are soldered in series so if the first one burns out you loose the rest
Iron cross audio does these repairs as well as a couple of other forum members , depending on you dealer they may be able to swap you out a unit fairly quick which is their SOP
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #9 of 10 (permalink) Old 06-02-2014, 05:36 AM
Attachment 124025
LEDs on that board are in paired series. If you loose one, you just loose its pair, not all of them.
racer-x is offline
post #10 of 10 (permalink) Old 06-02-2014, 08:20 AM
Gray Beard
lundboy1's Avatar
See that missed info given elsewhere can always be corrected here thank you x
lundboy1 is offline
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 11:09 AM
stock stereo backlight color chris636 Lighting 3 07-06-2014 10:16 PM
How to change Radio Backlight to Blue? cpo_roadglide Lighting 3 06-25-2013 05:17 AM
HK Stereo Backlight flicker? dspencer Audio 6 04-29-2012 09:16 PM
right handlebar controls and radio not working (02 e/glide classic convert r/glide) criio1 Troubleshooting for Road Glides 1 07-16-2011 05:34 PM
