Speakers wont fit !!!!! - Road Glide Forums
post #1 of 23 (permalink) Old 06-02-2014, 08:29 PM Thread Starter
rwb1967's Avatar
I just buttoned up the install of my new PBR300x2 and a set of Rainbow 6.5" speakers in my 2013 Road Glide....got it all dialed in, sound great...even wrapped the speakers in a thin layer of poly-fill as suggested .
Went to put the outer fairing back on and it doesnt fit...WTF. Found that my crossovers were in the way, moved the crossovers and it almost fits perfectly...except the speakers hit the fairing now.
I used a set of E-bay speaker adapters and the 6.5" Rainbows I installed are approx. 2 1/2" deep...so with the adapters say 3" total. Anyone else have this problem?? I even pulled off the poly fill and they still hit.
Now I have to find another set of "shallow" mount components to fit the fairing, since I already removed 2 gauges to install the tweeters. Can I safely swap out the "woofers" without replacing the tweeters and crossovers??
What component set ups has everyone else used in their Glides??
Thanks in advance for the help...I'm done bitchin' now !!
F.T.W.
rwb1967 is offline
post #2 of 23 (permalink) Old 06-02-2014, 08:56 PM
With the 2 sets of adaptors I have they are offset to one side, took some screwing with to get them in the right way so the speakers didnt hit
Jims79FLH is offline
post #3 of 23 (permalink) Old 06-02-2014, 09:05 PM Thread Starter
rwb1967's Avatar
The adapters do have a "conical " shape but sitting flat on a table they are the same height all the way around...does that make sense?? Meaning 1 side is not higher than the other....I will have to look at mine tomorrow.
thanks
F.T.W.
rwb1967 is offline
post #4 of 23 (permalink) Old 06-02-2014, 09:38 PM
thanks
Mine are the same height across, the 5 1/4 and 6 1/2 holes are offset to one side.
post #5 of 23 (permalink) Old 06-03-2014, 08:09 AM Thread Starter
rwb1967's Avatar
So maybe spinning the "high" side 180 degrees will give me some clearence...I will check it out.
thanks
F.T.W.
rwb1967 is offline
post #6 of 23 (permalink) Old 06-03-2014, 08:30 AM
thanks
Yep, you want the offset to the inside closest to the radio
post #7 of 23 (permalink) Old 06-03-2014, 08:57 AM
I used Hawg wired adapters. They only went on one way. If you mounted them wrong the screws the hold the speakers on would bottom out on the OEM mount.
I just mounted Infinity Kappa 6.5 and everything fit good. I even used foam speaker surrounds.
post #8 of 23 (permalink) Old 06-03-2014, 09:24 AM Thread Starter
rwb1967's Avatar
Hopefully moving the rings will work....looking at other speakers , mine are the same depth as most...couldnt believe they didnt fit....after running wires, and soldering everything and making it nice ands neet...I was ready to smash something when the fairing didnt go on ....lol
F.T.W.
rwb1967 is offline
post #9 of 23 (permalink) Old 06-03-2014, 09:43 AM Thread Starter
rwb1967's Avatar
Qick speaker question while I'm at it....my speakers are rated @ 100 watt rms...150 peak..these are 4 ohm speaker...the pbr300x2 is rated @ 100 continious @ 4 ohm.
Will running the speakers at RMS cause any damage?
Also what speakers are people using for a 2 ohm load @ 150 watt with the pbr300x2 ? I looked at a bunch and most of the popular speakers people are running are rated no where near 150watt rms...am I missing something?
F.T.W.
rwb1967 is offline
post #10 of 23 (permalink) Old 06-03-2014, 10:30 AM
The PBR 300 x 2 is actually delivering about 140 watts per channel @ 2 ohms. As with any amp , you never want to run wide open . I got the gain set to about 5 . It seems like a good setting for the Infinity kappa's I'm running.
Speaker help HErtz sv165 wont fit emt-p Audio 6 06-02-2016 02:11 PM
140 90 16 on 2000 wont fit?advise please dirtracer27x Wheels and Tires 6 04-02-2014 03:29 PM
2012 RGU wont start after cam swap Bluchevypick Troubleshooting for Road Glides 5 04-20-2012 10:35 PM
changed bars now bike wont start NO4NBIKES Controls & Handlebars 4 01-02-2012 10:06 AM
wont start The instigator Road Glide Specific Discussions 8 03-24-2011 09:20 PM
