Aftermarket radio RFPBR300x4 - Road Glide Forums
post #1 of 3 (permalink) Old 06-13-2014, 06:33 PM Thread Starter
sportyguy69's Avatar
Been running the stock HK deck with a RF PBR300x4 amp pushing 4 6.5 speakers. When upgrading to a aftermarket stereo, do I hook up the new deck the same way to the RF or use RCA cables? Which is the best way?
If your going to do something give it all you got, might be the last time you ever do it !!!
sportyguy69 is offline
post #2 of 3 (permalink) Old 06-13-2014, 07:51 PM
The RF amp will still work best with the high level input, should you decide to change amps , different story.
post #3 of 3 (permalink) Old 06-14-2014, 06:00 PM Thread Starter
Thanks for the reply.
2 amp setup question, Hogtunes and RFpbr300x4 Mopar1 Audio 14 03-29-2013 09:12 AM
Installing aftermarket amp to OEM radio Q's ddaarr Audio 9 03-16-2012 07:37 PM
Will an aftermarket radio fit without any adapters? GLYDDN11 Aftermarket Accessories 8 02-23-2012 12:23 AM
Aftermarket Radio help ffhd05 Road Glide Specific Discussions 12 02-17-2012 04:17 PM
Aftermarket radio install options JuicedHD Audio 2 04-04-2011 05:10 AM
