Need speaker upgrade... Any advice? - Road Glide Forums
post #1 of 12 (permalink) Old 06-15-2014, 08:35 PM Thread Starter
Guys I'd like to do this right the first time so I thought I might ask about what you've been happy with. I want some good clear speakers to replace the stock ones but not sure if an amp is necessary too. Will a speaker upgrade alone make that much of a difference or do I go all out and install an amp too? Eventually I will be getting the saddlebag lids and speakers back there but to start I'm going for front upgrade only. Any recommendations will be appreciated.
Thanks
Jimb416 is offline
post #2 of 12 (permalink) Old 06-15-2014, 09:05 PM
rwb1967's Avatar
Having just done this last week, here is my .02....buy a set of decent component speakers, the best u can afford...Focal, Soundstream, JL audio are a few great brands ...mount the tweeters in the fairing in place of 2 gauges(u pick) and yes , DEFINITELY use an amp. The sound difference and quality is night and day with the copmponents and an amp.
Don't, I repeat do not buy a cheap set of E-bay speaker adapters, use the Hawg Wired adapters as they bolt in perfectly in 5 minutes.
Solder ALL your connections, even though you will be tempted to use quick connects, don't do it.
You can get a good set of speakers , amp, and adapters for less than $400.
Money well spent in my opinion as my system sound excellent.
Good luck and let us know what u decide.
F.T.W.
rwb1967 is offline
post #3 of 12 (permalink) Old 06-15-2014, 09:31 PM
If you plan to upgrade, definitely get an amp also, as you probably already know after about 3/4 volume the OEM stereo starts to distort, with new speakers it doesn't get any better. You need a little power to push your speakers. Do a search through the audio threads to get some ideas.
post #4 of 12 (permalink) Old 06-15-2014, 09:40 PM
JJSW1283's Avatar
Think about upgrading the head unit to aftermarket also if you haven't alreadly.
JJSW1283 is offline
post #5 of 12 (permalink) Old 06-15-2014, 10:05 PM
glidethru's Avatar
J & M Rokkers and a 300 watt Rockford, I can hear music loud and clear, at 70+
MAGNA FLOW "Top Guns
Wild Ones 12" Chubbys
glidethru is offline
post #6 of 12 (permalink) Old 06-16-2014, 01:58 AM
NakedSnowman's Avatar
Here is my sound system....Although the bike has gone thru a MAJOR transformation, the amp and speakers are the same. The deck is still an Alpine, but no CD player...Alpine ida-x305s with iPod classic in glove compartment.
https://www.youtube.com/watch?v=eqcKdgekChE
NakedSnowman is offline
post #7 of 12 (permalink) Old 06-16-2014, 03:40 AM
tmd
Been running J&M's on my last two bikes. Have checked out other systems but have been perfectly happy with them. Customer service and support is second to none as well. Oh and spring for an amp if you want the most out of an upgrade.
tmd is offline
post #8 of 12 (permalink) Old 06-16-2014, 08:19 AM
glidethru's Avatar
Definitely a party on wheels. Funny how the sound changed walking around your bike at different angles .
post #9 of 12 (permalink) Old 06-16-2014, 09:48 AM
JMJOHN
JMJOHN's Avatar
another good choice is here, http://www.jmcorp.com/ProductDetail....AK-HR06-1802SP probably the best sound available for the $$$ spent ,,,,,
in addition, the J&M/RoadGlide forums 15% discount Promo code would help the price even more ,,,,,,,,
JMJOHN ----
JMJOHN is offline
post #10 of 12 (permalink) Old 06-18-2014, 10:17 PM
otis2013's Avatar
Location: Bend Oregon, Mountains rivers and 300 days of sunshine
Check out Hawgwired and definetly change your head unit. I have a 400 Watt Amp with 6.5 speakers (2 in my lower Fairing) and I'm still not pleased with my tunes. Now I'm looking at a JVC marine head deck for only $109....should have changed my deck the first time....mo money, mo money. Good luck, its a great process
2013 RG, Dragos True Duals with Dragula mufflers, PV tuner, big Sucker, Vented Lowers, 19"boards and stuff....
otis2013 is offline
Tags
amps , sound , speakers
Need advice new radio and upgrade speakers? Wlarson331 Audio 3 08-22-2018 09:04 PM
Need advice on audio upgrade Jsteg Audio 4 07-19-2018 04:14 PM
Need advice on stereo upgrade 2015 RG Skull Audio 15 03-29-2016 11:10 AM
Time for an upgrade - Need advice McGarnicle Audio 13 02-18-2014 08:48 PM
Cam upgrade... Need some advice NTEXRG Engine Related 9 04-16-2012 09:10 AM
