Home run !! - Road Glide Forums
post #1 of 5 (permalink) Old 06-21-2014, 11:13 AM Thread Starter
sportyguy69's Avatar
Home run !!
About 3 years ago I did the inner fairing speakers mod. After multiple speaker combos, and decks I think I finally found the set up. This is just my personal experience and opinion.
First set up
Stock HK deck
Rockford Fosgate PBR 300x4
Polk Audio DB651
The Polks lasted about 9 months before the tweeters gave out.
Second set up
Stock HK deck
Polk Audio DXI651
Third set up
Alpine UTE42BT
Polk Audio DXI651
Again the Polks gave up the ghost after about a year.
Forth set up
Alpine UTE42BT
Rockford Fosgate P165 speakers
Alpine UTE42BT started having issues being controlled by the Hawg Wired kit. Volume up made the song go back to the beginning. Also doing some other weird stuff.
Fifth set up
Sony MEX-M50BT
Rockford Fosgate PBR3000x4
I think I finally found the right combo. Streaming music to the Sony via BT and setting up the Sony. This combo blows away any of the above set ups. An yes you can see the display in direct sunlight if anyone is wondering. Just wanted to share my experience so others don't have to go down the same road I did. Sorry for the long write up.
If your going to do something give it all you got, might be the last time you ever do it !!!
sportyguy69 is offline
post #2 of 5 (permalink) Old 06-21-2014, 11:46 AM
HUTMO's Avatar
Homerun
Wow.
Glad u figured it out. LOts of effort and cash it seems. I hope it was worth it.
HUTMO
HUTMO is offline
post #3 of 5 (permalink) Old 06-21-2014, 12:04 PM Thread Starter
I blame it all on this forum !!!.........LMBO
post #4 of 5 (permalink) Old 06-21-2014, 12:24 PM
When you go to the 6th set up, try a different amp and you will be more amazed. Before anyone gets upset, the RF is a good amp, it's just an amp with a class A power supply that can work well with the rca low level input sounds better IMO, and yes, I've had 4 RF amps so I'm speaking from experience.
post #5 of 5 (permalink) Old 06-23-2014, 05:56 AM
Trvlngman357's Avatar
Home run !!
I was running 2 of those RF 300x4 amps using RCA-low level input connections and recently just did the high level hook up and I have to say WOW! What a difference it made in how loud and clear the music was I had to totally retune my setup.
Trvlngman357 is offline
Finally got her home SJ9125 *General Road Glide Discussions/Pictures 8 08-25-2010 10:50 PM
Brought Her Home Today HUTMO *General Road Glide Discussions/Pictures 36 05-07-2010 04:18 PM
brought the 2010 FLTRX home March 30th! Deuce Bigelow *General Road Glide Discussions/Pictures 14 04-12-2010 06:43 PM
Finally a place to call home!!! jbrawkus *General Road Glide Discussions/Pictures 10 03-01-2010 09:50 PM
Vid of home town connector General Off-Topic Discussions 5 01-31-2010 05:36 PM
