No Sound Help please - Road Glide Forums
post #1 of 11 (permalink) Old 06-23-2014, 09:26 AM Thread Starter
While riding into work this morning the radio sounded like it clipped in and out once and I lost sound completely. I am running the stock HK head unit, RF PBR300x4 amp, 4 x POLK 6.5. Itís been in since last summer, the gain was adjusted to 5 when it was first installed and I was experiencing the clipping in and out periodically at higher volumes. I reduced the gain to 4 and it has been playing fine since March. From reading the issues on this forum with this amp, I believe that the amp is dead or at least dying but wanted to see if there were any tests that I could conduct to validate that assumption instead of it being the head unit. The head unit is still displaying as normal but there is just no sound.
If the amp is toast, what are recommendations for running the 4 speakers?
infernomd is offline
post #2 of 11 (permalink) Old 06-23-2014, 07:33 PM
Blown fuse on the amp or a bad ground will cause your problem. Check your ground connection.
post #3 of 11 (permalink) Old 06-25-2014, 08:03 PM Thread Starter
I haven't had a chance to pull the fairing but I did check the in line fuse. The fuse has burn marks on the connector, the metal is raise but not blown. At this point I think the fuse did not blow and unless there is a fuse built into the amp, it might be dead.
Now the real question is what could have occurred to cause this problem? The power is run from the battery to the amp, the radio is connected through the stock speaker wires and the four speakers are connected to the amp. The amp is set at HP and the gains are at 4.5.
I am not great with the wiring aspects, what could have caused the issue at hand. I know I was sitting in traffic that morning and the engine did get hot, could that heat have caused the issue with the fuse since the in line fuse is under the seat near the majority of the engine heat?
post #4 of 11 (permalink) Old 06-26-2014, 05:13 AM
Smile
A fuse can look OK but be bad, check it with an Ohm meter of put a known good fuse in.
Discolored or melting of a fuse holder means excessive current has been flowing in circuit. Not enough current to blow the fuse right away but enough to eventually cause a problem. Heat from the motor would not cause this issue unless the fuse holder was actually touching the engine.
If a new fuse works but eventually blows again then suspect the amp.
[email protected]
pilot is offline
post #5 of 11 (permalink) Old 06-26-2014, 06:10 AM
OKBigD's Avatar
What gauge wire is ran to the amplifier? If the wire is undersized it can cause increased amperage draw to compensate for voltage drop... check the wiring between the amp and the battery make sure the wire didn't get damaged....
OKBigD is offline
post #6 of 11 (permalink) Old 06-26-2014, 09:35 AM
I am curious! Why would anyone run a gauge wire to the amp. The amps main power wires should be hooked directly to the battery. The Accessory plug in the headlight is used to activate the amp when the volume is over a certain setting not as a main power source.
Sounds like a bad ground, a bad ground will cause the wiring to overheat.
post #7 of 11 (permalink) Old 06-26-2014, 09:53 AM
Ah come on Fe Mark, like 16 gauge wire vs 22 gauge wire, ya know
reds4 is offline
post #8 of 11 (permalink) Old 06-26-2014, 10:39 AM
PGR
PGR's Avatar
Fe Mark ........
Ron..........................
PGR is offline
post #9 of 11 (permalink) Old 06-26-2014, 11:07 AM
Oh! That gauge as in size wire. lol;
post #10 of 11 (permalink) Old 06-26-2014, 11:48 AM
Best way to check is to remove the outer fairing and remove the amp from the ckt or temporarily attach the output of the HU to the speakers, many things could have gone wrong to cause the amp to die that have nothing to do with the fuse.
Help Please: Ignition / Power No Go Skid_ro Troubleshooting for Road Glides 1 05-29-2017 08:51 PM
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 09:51 AM
Help please stalls no codes creed Troubleshooting for Road Glides 5 07-22-2012 08:08 PM
no sound from GPS ronwa Troubleshooting for Road Glides 1 06-11-2012 10:32 PM
Need help: No sound from Factory Stereo when Running DED HD Audio 8 06-30-2011 08:48 AM
