Amp setting high or full? - Road Glide Forums
post #1 of 8 (permalink) Old 06-23-2014, 03:45 PM Thread Starter
Have a Arc Audio. What setting do you put on a bike high or full range?
hotdog1922 is offline
post #2 of 8 (permalink) Old 06-23-2014, 04:22 PM
Bluchevypick's Avatar
A little more details? What speakers but I run mine on Full.
Bluchevypick is offline
post #3 of 8 (permalink) Old 06-23-2014, 07:27 PM Thread Starter
I have the Hertz component hi energy. Stereo shop told me to run on high so you don't blow speaker.
post #4 of 8 (permalink) Old 06-23-2014, 07:49 PM
You will want some type of mid and low range. You can adjust that from the deck
post #5 of 8 (permalink) Old 06-24-2014, 08:03 PM Thread Starter
Curious what everyone else is running
post #6 of 8 (permalink) Old 06-25-2014, 05:44 AM
hometoast's Avatar
I'm not running your same equipment. I'm using the J&M Rokker XX speakers which have their own 80hz(I think it's 80hz) crossover built in. The head unit (alpine hd149bt) was already set to 80hz anyway. So I run FULL on the amp (soundstream pn2.350d).
If I didn't already have TWO x-overs working, I'd have set the amp at HPF and adjusted to 80hz.
What head unit are you running? It certainly will NOT HURT you to run hi-pass on your amp to protect your speakers.
2013 Candy Orange FLTRX
hometoast is offline
post #7 of 8 (permalink) Old 06-25-2014, 06:51 AM Thread Starter
I'm running the stock head unit right now. Would like to get a full sound out of the speakers but don't want to risk blowing them.
Did you run your system with the stock head and did you see a big difference with the Alpine? That's going to be my next upgrade. Read good things about that deck you have.
post #8 of 8 (permalink) Old 06-25-2014, 09:39 AM
hometoast's Avatar
Nope, headunit and amp went in the same time. It's worth it for the Bluetooth/Pandora/USB sources alone.
Freq setting on diamond amp BigBubba Audio 1 12-31-2016 05:44 AM
need help setting amp roof70 Audio 1 09-20-2014 09:56 AM
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 09:44 AM
How high should high beam really be jacksonfdny Lighting 4 09-11-2012 05:37 AM
Need help setting up my wife's Road Glide NCTim *General Road Glide Discussions/Pictures 5 11-09-2010 11:27 AM
