USB Extension cable advice - Road Glide Forums
post #1 of 5 (permalink) Old 07-10-2014, 10:55 AM Thread Starter
Does anyone run their extension cable to their dash compartment? I'm installing my new HU and system today and I'd like to run the extension from the rear of the HU to my compartment on my Road Glide. Is there an adapter or something that you guys know about or should I just drill a hole and slide the cable through and call it a day?
McGarnicle is offline
post #2 of 5 (permalink) Old 07-10-2014, 11:07 AM
Q-Hog's Avatar
Just drill the smallest hole for it to fit through or cut the size to fit the cable port.
Q-Hog is offline
post #3 of 5 (permalink) Old 07-10-2014, 11:24 AM
I bought a flush mount usb/aux extension from amazon, works perfectly.
post #4 of 5 (permalink) Old 07-10-2014, 11:32 AM Thread Starter
That is exactly what I'm looking for thank you sir
post #5 of 5 (permalink) Old 07-10-2014, 11:35 AM
OKBigD's Avatar
This is exactly what I did and mounted it in the glove box... Even has the 3.5mm adapter in case I need to use it....
OKBigD is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
2015 Cable extensions - need advice Sethjamto Controls & Handlebars 2 12-23-2014 05:16 PM
Antenna extension cable from custom to tour pack nashambassador48 Audio 2 06-28-2012 05:41 PM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
