Engine Noise coming thru my speakers-HELP - Road Glide Forums
post #1 of 25 (permalink) Old 07-13-2014, 04:34 PM Thread Starter
otis2013's Avatar
Location: Bend Oregon, Mountains rivers and 300 days of sunshine
Heres what I got. Just upgraded my system with a new Kenwood Marine media center Deck and remote Amp controller. Replaced the HK deck. Already had hawg wired RS 400 Amp and 4 speakers.
Up late last night eliminating a squeal out of my speakers which was present with the bike in acc. mode. The problem was a bad connection at the Amp. Cleaned all connections with electrical contact spray cleaner and applied a little dielectric grease...No squeal.
Put the fairing back on (anyone using X-TRIM, PITA) and hooked up my BI-ZENON HID lights.
Problems: 1. Horrible squeal and engine noise which increased when I roll on the throttle. Removed the headlight bezal and disconnected the headlights (The left never came on after putting the fairing back on, Hi Or Lo beam) Squeal seemed better but engine noise persists.
2. No left headlight. Switched Left and Right headlights. Left was dead. Re-checked left sided connections....could'nt get the left headlight to turn on.-ANY Ideas out there?
2013 RG, Dragos True Duals with Dragula mufflers, PV tuner, big Sucker, Vented Lowers, 19"boards and stuff....
otis2013 is offline
post #2 of 25 (permalink) Old 07-13-2014, 05:52 PM
Spark plugs
If you are running iridium plugs you might want to try the standard plugs, as my thundermax tuner picked up a RF interference from these plugs, and they recommended switching back to standard plugs, your stereo could be suffering same RF interference...just a thought..
exracer2002 is offline
post #3 of 25 (permalink) Old 07-13-2014, 06:14 PM Thread Starter
otis2013's Avatar
Plugs are stock. Thanks for the input though. Its got me stumped. Ill call hawg wired tomorrow. Maybe the HID ballast or the way the Amp gets acc power thru the cig. lighter
otis2013 is offline
post #4 of 25 (permalink) Old 07-13-2014, 06:24 PM
I had a similar problem and installed a filter, problem solved.
post #5 of 25 (permalink) Old 07-13-2014, 06:35 PM Thread Starter
otis2013's Avatar
Thats what I want to hear. What filter?
otis2013 is offline
post #6 of 25 (permalink) Old 07-13-2014, 06:43 PM
Let me see if I can find the link, I bought it off eBay.
post #7 of 25 (permalink) Old 07-13-2014, 06:51 PM Thread Starter
otis2013's Avatar
Looking at a good article on Crutchfild.com on noise supression. Looks like I'll be pulling that fairing off again.
otis2013 is offline
post #8 of 25 (permalink) Old 07-13-2014, 06:53 PM
I can't do it from my tablet, but I can tell you it's a blue 4 channel filter with rca jacks in and out, cost is $30 it's an over seas seller, but it came fast. Just go to ebay and do a search for car audio filters, it'll come up. If you look further you'll probably find the same thing for a better price, I paid around $20, but it was over a year ago.
post #9 of 25 (permalink) Old 07-13-2014, 07:19 PM Thread Starter
otis2013's Avatar
Thanks DBELL, I think you hit the nail on the head. From what ive read my Amp being powered thru the cig. lighter may be an issue as well.
otis2013 is offline
post #10 of 25 (permalink) Old 07-13-2014, 07:27 PM
EasternSP's Avatar
You could run a separate line to the fuse box instead of taking off the cigarette lighter.
Ken,
- 2006 RG 107/DD6/FatBagger 200mm Rear end w/Car tire
- 2016 RGU with Car Tire
EasternSP is offline
installed amp, now feedback thru speakers Quickster Audio 9 09-27-2013 08:16 AM
SWIII-who's coming thru Montana Wooden Nickel ARCHIVES-SWIII St. George, UT 39 07-26-2013 07:25 PM
Suspicious noise from engine. help! Luke Duke Troubleshooting for Road Glides 4 05-10-2013 12:29 PM
HELP... is this engine noise normal ? Still Grumpy *General Road Glide Discussions/Pictures 4 12-05-2012 10:26 AM
Noise coming from underneath fairing Mikey Rod *General Road Glide Discussions/Pictures 2 05-13-2011 03:09 AM
