Question for audio experts - rear speakers in/out - Road Glide Forums
post #1 of 6 (permalink) Old 07-16-2014, 06:37 PM Thread Starter
I have a 12 CVO with speakers in the rear lids. The amp says MTX on it. When I have it up loud the rears will cut in and out intermittently. I have had it low volume for a bit and could not reproduce by shaking connections, wires, etc. I am not an electrician. I can only guess maybe the amp in the rear bag is getting weak but all speakers should cut out if that was it correct?? Amp didn't feel hot. Any suggestions.
Thanks in advance, Jason
jc12cvo is offline
post #2 of 6 (permalink) Old 07-16-2014, 07:22 PM
The speakers could be bottoming themselves out causing the amp to lose output for a second. If the amp is only running those two speakers that is all that will cut out. Try either turning the crossover frequency up a little bit if the amp has that adjustment or turn the gain down on the amp if no crossover. What model amp is it?
V&H Exhaust//Stage 1 intake//6k HIDS//12" KW Flare//12" Buky Assaults// Arc Audio 125.2// Alpine 5 1/4 components// Alpine head unit//color matched gauges//chrome this chrome that
FLTRick is offline
post #3 of 6 (permalink) Old 07-16-2014, 08:19 PM Thread Starter
Has MTX 441ELH1722 just below a bar code and says Mitek REV A 76000141 on it. I didn't see any adjustments on it so not sure what it is but when I unplug it the rear speakers go out. Has like a big 12 or so pin connector running to it.
Could it be an aftermarket controller? I bought the bike second hand so not sure.
jc12cvo is offline
post #4 of 6 (permalink) Old 07-17-2014, 06:00 AM
Sounds like it's only running the rear speakers. Try unplugging just one rear speaker and play it. See if it cuts out again. If it doesn't than the speaker you unplugged is bad. If it does try the other side. The problem is most likely caused by a bad speaker.
FLTRick is offline
post #5 of 6 (permalink) Old 07-17-2014, 10:46 AM
Eshaw301's Avatar
Originally Posted by jc12cvo View Post
When I have it up loud the rears will cut in and out intermittently. I have had it low volume for a bit and could not reproduce by shaking connections, wires, etc...
Classic symptom of an amp going into protection mode on those particular channels. I just had that happen a few months ago with my rokker 500w amp. Front channels would cut out intermittently when music was up loud. The channels in your amp are bad. Good thing is that there are some great amps out there to replace it with that wont cost you a ton of coin. Let us know what you decide.
"DUDE!...Your exhaust is making the ground shake!" Circa March 2014, Born Losers MC, Atlanta.
Eshaw301 is offline
post #6 of 6 (permalink) Old 07-18-2014, 06:42 AM
Neano62's Avatar
Call these Guys!,....they 'R' the Xperts.
510-894-2999
for what its worth, I was gonna say this was ur amp clipping, but I aint no xpert! But I am in charge of my Spaghetti Whse underneath the H-QQ-D. hehe-hehe
[/IMG]
Neano62 is offline
got a question for Garmin experts HogWild GPS 7 07-22-2013 01:59 PM
Damn computer problems - computer experts? CHAINSAW General Off-Topic Discussions 28 05-23-2012 02:47 AM
? for the experts capt64 Audio 0 06-16-2011 05:13 PM
Question for the experts pte359 Audio 2 04-14-2011 12:32 AM
Asking the Experts Nevadasun ECM/Fuel Management systems 4 12-12-2010 10:07 PM
