What size power and ground - Road Glide Forums
post #1 of 4 (permalink) Old 07-26-2014, 09:36 PM Thread Starter
What size power and ground for amp
Hello all. Just picked up a arc audio mpak6 (moto 602 6.5 speakers and an amp) from the classifieds and it came with everything but the power and ground cables for the amp. I don't know much about hooking up a set of speakers and amp but it has pretty good directions so I figure I'll do it myself. With out having to order a specific set of wires, is there something off the shelf (and Guage size) that you guys know of that I could use locally. Should I put a fuse inline on the power wire? Thanks in advance.
suomy1 is offline
post #2 of 4 (permalink) Old 07-26-2014, 09:53 PM
I used 10 Guage wire from battery to amp. I also installed a inline fuse about 6" off the battery.
Big_gary is online now
post #3 of 4 (permalink) Old 07-26-2014, 09:56 PM
The power kit that arc audio sells I believe comes with 10 gauge power and ground. 30 amp fuse should be no more than 6" from the battery.
V&H Exhaust//Stage 1 intake//6k HIDS//12" KW Flare//12" Buky Assaults// Arc Audio 125.2// Alpine 5 1/4 components// Alpine head unit//color matched gauges//chrome this chrome that
FLTRick is offline
post #4 of 4 (permalink) Old 07-26-2014, 10:01 PM Thread Starter
Right on. Thanks for the replys. I'm sure arc will sell me a set but I'm chompin at the bit wanting to hear these suckers.
suomy1 is offline
AMP Install Power & Ground Wire Routing wevsspot Audio 4 05-08-2015 09:27 AM
Amp wire and ground point Venomized Audio 6 01-09-2014 11:07 PM
How to run power/ground for amp. daninfamous Audio 6 06-01-2013 06:49 AM
Building a 117 from the ground up. DragoBikeWorks Engine Related 66 10-03-2012 09:16 PM
Putting the Glide on the Ground??? jbrawkus *General Road Glide Discussions/Pictures 10 01-11-2011 08:30 PM
