Lost reception and ?? on amp install - Road Glide Forums
post #1 of 3 (permalink) Old 08-03-2014, 05:11 PM Thread Starter
Thanks in advance for your help………….I know just enough about this electrical and audio stuff to be dangerous so I’ll apologize now for the long post, just trying to get you all the detail I can. I’ve read a lot of the amp threads and kind of have a plan, but still got some doubts and need to bounce it off you guys first……………
To start we’re talking 2013 FLTRX with stock HU and J&M Rokker 7.25 speakers (yeah I know, but I put them in before I ever knew about this site). A guy owes me for some work and offered me a pretty much brand spankin’ new RF PBR300x2 and I’m going to take it because I’m relatively certain I’ll never see cash otherwise. Other than that I’m not obsessed with audio so it should keep me happy. So here’s my question:
I have the HD hidden antenna mounted already (note that it taps off the cig lighter spade tabs for power) and it worked just fine – until I got the genius idea to install a USB charging port in the glove box and used mini-taps to tap into the power supply. Of course I tapped into the cig lighter line for the USB charger, confirmed that it had power and would charge my phone, and slapped the fairing back on and headed down the road as happy as a pig in s***. The next day I turn my radio on and of course no reception at all, the only thing that has output is the CD and aux port. Take the fairing back off, pull the taps for the USB charger and of course the reception is fine.
I still want power to my USB charger and I want to keep the hidden antenna set up. Do you think I lost reception simply because I’m pulling too much current off the line to the cig lighter or is the USB charger interfering with the hidden antenna and causing the loss of radio reception?
I guess the other easy power supply to get to is the lights. Should I move the USB charger to tap off one headlight and then tap off the other headlight for the on input for the amp when I get it? Or leave the USB charger on the cig lighter and move the hidden antenna to the light for power? Am I just asking for more problems having stuff tap off the lights? If so, what else could be used for power? I thought about running something from the accessory port under the seat, but that’s on the same circuit as the cig lighter and figured I would get the same interference as being tied into the cig lighter.
roadie13 is offline
post #2 of 3 (permalink) Old 08-03-2014, 05:34 PM
Just a thought, if you don't have Daymakers yoi could always use the orange/white lead on the light Harness to power your USB. When you install the amp you're going to want to run a separate fused power wire from the battery.
post #3 of 3 (permalink) Old 08-03-2014, 05:44 PM Thread Starter
Thanks Dbell......I don't have daymakers now, but do hope to snag a pair when people start trading for the 15s in a few weeks...............
So if I did have daymakers would it cause a problem tapping into the O/W wire for power?
I understand I'll have to run a fused line straight to the battery for main power for the amp, but isn't there a second line needed that actually turns the amp on - that's what I was referring to tapping into the other side of the lights for,
roadie13 is offline
FM reception with BT2180 amp vs Diamond Micro 2V2? macabra11 Audio 13 05-26-2017 12:02 PM
Radio Antenna and reception issue Southpaw Slim Audio 5 03-28-2016 07:42 PM
A M Radio Reception Rant Fahred Audio 1 10-08-2012 07:55 PM
2012 Radio reception cloud Audio 7 07-20-2012 11:33 PM
RG Ultra FM reception ackmoe Road Glide Specific Discussions 15 04-14-2011 12:25 AM
