Anyone using the Jensen HD1BT audio? - Road Glide Forums
post #1 of 29 (permalink) Old 08-08-2014, 09:35 AM Thread Starter
jprider4life's Avatar
I'm thinking of upgrading my stock 04 radio, came across the Jensen hd1bt radio, looks and seems good for a replacement but would like more info on it and see if anyone has or knows anyone that's using one.
jprider4life is offline
post #2 of 29 (permalink) Old 08-08-2014, 12:53 PM
I spend a lot of time on another forum, that one has a couple of guys that have them and they like them a lot. Only complaint I heard was the RCA Pre-Amp outs are a little "fragile". Otherwise they all seem happy. Its not actually made by Jensen, its made by a company that makes radios for tractors and heavy equipment, its supposedly built like a tank.
usg436o likes this.
Kave Dweller is offline
post #3 of 29 (permalink) Old 08-08-2014, 04:13 PM
eme56's Avatar
I just installed this week. My stock radio quit. A circuit board split. So I ordered the Jensen and the auxiliary adapter. The installation was easy. It does bolt right in. The only catch was I had to do a little wire rerouting. The plug is on the opposite side of the radio, so it took a little time to make sure everything reached and wasn't stretched. The handle bar controls work fine. The unit sounds great as well. I have a Hogtunes 140 watt amp, 5x7 speakers, and tweeter pod. I did have to turn off the "Loudness" setting. With it on, the sound distorted just above 1/2 volume. Off, I can almost full volume (38 out of 40) with high quality (320) MP3 files off a USB drive. I couldn't go past 12 bars without distortion on the old Radio Sound unit on a clean CD file (CDA not MP3). I cut a 1.5" hole is the back of the left glove box and mounted the auxiliary connector there. It is also waterproof with a rubber front cover. That gives me Aux and USB inputs to the unit (they are rear mounted). It will be nice to have control of the flash drive from the bars instead of using an MP3 player through the front panel input on the old radio. I also has a remote amp turn on, so my amp won't be on while the bike is starting or sitting with ignition or accessory on.
I haven't had time yet and it's been raining, so I can't give you an "on the road review" yet. The screen is bright and is adjustable for brightness and contrast, so it should be ok in sunlight. I can tell you my neighbor thought is sounded great. I was in my garage which is in my basement with the garage door down and he was in his front yard trimming bushes. He was stunned when I told him that was my bike radio.
I did snap a couple pics before I finished up the wiring and put the fairing back on.
I did look at the Hawg Wired control interface and the V-Twin Audio mounting kit w/waterproof cover, but then I was at around $300 before even looking at an Alpine CDE-HD149BT radio.
If you want, I can give a better report and pics from the dash side after this weekend, if it ever quits raining.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
post #4 of 29 (permalink) Old 08-08-2014, 08:56 PM
Love it
Hayabusa1967 is offline
post #5 of 29 (permalink) Old 08-08-2014, 10:58 PM
glide1's Avatar
Originally Posted by Hayabusa1967 View Post
Love it
Hey busa, Where did you get that "Road Glide" Cover thingy for your gas Tank Cowling? I like it..
glide1 is offline
post #6 of 29 (permalink) Old 08-09-2014, 06:33 AM
We had a customer bring one by and asked us to install.
We were not impressed.
Features were fine, but audio quality was lacking.
No AVC...which was a bit misleading because the manual shows the AVC circuit in the harness.
Week later he was back...lost right channel...bad RCA connector.
He took that opportunity to return it and install a Sony from Biketronics...much happier.
racer-x is offline
post #7 of 29 (permalink) Old 08-09-2014, 06:49 AM
piggs's Avatar
i too put one in last week. relatively easy install. upgraded the speakers and amped it too. BUT.. the radio didn't fit the stock hole 'exactly' so I had to fill gaps with sillycone (black).. 2 days later the volume control (at the grip) stopped working and also 2 days later (probably related) when the left turn signal is on, it disturbs the sound with static, on off, on off..
and the red face light isn't working either.
it isn't easy to see whats on the display from riding position..
will take it apart again rewire and change handle bars (again) at the same time. so my opinion is not yet in.. when it worked (for 2 days) it sounded good but haven't had it out at 80mphs to draw a solid conclusion..
the main reasons I bought it was : hand controls like stock (well almost) and the Sirius feature and did put in the stuff so it will work but have not subscribed yet and the USB input feature (right glove box)..
OH.. and the volume does not increase and decrease as one goes faster and slower like the stock unit.
Piggs, SemperFi
2013 FLTRX Denim
piggs is offline
post #8 of 29 (permalink) Old 08-09-2014, 03:00 PM
AtomiCapricorn's Avatar
I just put one in as well. Idiotically simple to install. Bluetooth and iPod controls work well, and these are the two reasons I installed this head unit (HK iPod interface started acting hinky). No road test yet because I'm also installing a Hawg Wired CS300, 14" apes, and a hydraulic clutch. Hoping to have it done by tomorrow.
Oh yeah, the Jensen USB/Aux interface plug is also incredibly easy to install in either glovebox with a 1.5" hole saw. The leads are really, really long. You could damn near install it in a saddlebag.
Seriously, I should have waited another month or so to dig in to all of this. I'm doing it all in my gravel driveway (no garage; see sig pic) in hot ass Acton/Agua Dulce, California. It's 95 out right now. Yeesh. Rant over.
'13 FLTRX, BBP, Vivid Black painted inner fairing, 9" Windsplitter, 14" W1 Chubbys, Get-A-Grips, Daymakers, ABS, Cruise, Security, 4 Speaker HW/Jensen HD1BT System, Fuel Moto Jackpot Header/Nightstick Exhaust, Powervision, Fueling 543 cams (95HP/104TQ). Yay, me!!
AtomiCapricorn is offline
post #9 of 29 (permalink) Old 08-11-2014, 09:44 AM
How bad was the audio quality lacking? is it worse then the HK? I was thinking about it just for the Pre-Amp outs, as long as that signal is fairly clean, I think I'd be fairly happy with the other features (Bluetooth and skipping Pandora songs is my real goal).
post #10 of 29 (permalink) Old 08-11-2014, 11:59 AM
Eshaw301's Avatar
You'd be better off and a whole lot cheaper sending it to Iron Cross Audio. Google em....
"DUDE!...Your exhaust is making the ground shake!" Circa March 2014, Born Losers MC, Atlanta.
Eshaw301 is offline
Jensen HD1BT, can you run google maps through it chevjerico Audio 1 01-06-2017 06:59 AM
Thundermax autotune, Jensen HD1BT Sirius XM tuner, Edge Cut latches, docking station daryl_db Parts for Sale 6 03-18-2015 08:56 AM
Jensen HD1BT won't hold clock setting and other issues? chevjerico Audio 10 02-16-2015 07:02 AM
Can Google maps or mapquest play through a Jensen HD1BT? chevjerico Audio 0 01-31-2015 12:32 PM
